grahamastor opened this issue on Jun 10, 2013 · 3 posts
grahamastor posted Mon, 10 June 2013 at 4:26 PM
Attached Link: http://www.renderosity.com/mod/bcs/saucy-for-sexy-top-ii/88123/
Hi all,I'm still learning and using Poser 2010. I'm interested in creating a set of images where a piece of clothing (existing purchased add-on) is rendered shorter and shorter - such as a skirt, or "Saucy for Sexy Top II" where it shortened or given a shredded texture. Could someone provide me a way of doing this, rather than purchasing more add-ons - "teach a man to fish" as it were.
Many thanks,
Graham....
vilters posted Mon, 10 June 2013 at 4:41 PM
If you look closely at the content of that top, you will see that it uses a tranparancy map.
You could alter "paint" the transparancy map to make it render shorter and shorter and shorter.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
markschum posted Tue, 11 June 2013 at 4:54 PM
yup , transparency map for shorter or shredded clothing.
It is essentially a black/white image where black is transparent and white is visible. add an image map noode , load your mask image to it, and connect to transparacy channel.
there should be tutorials.
