Subject: Michael 4 oddity?
sturkwurk opened this issue on Jun 16, 2013 · 4 posts
sturkwurk posted Sun, 16 June 2013 at 10:22 AM
yeah, yeah, I'm about 6 years late with this question.  Has anybody ever encounted this... you load a base M4 - and when you apply M4 expression poses, the eye closes do the opposite of what they are suppose to?  just curious.
I came, I rendered, I'm still broke.
mackis3D posted Sun, 16 June 2013 at 11:38 AM
It's possible that the M4 expression poses you apply use also morphs from the morph ++ pack. The base M4 without the ++ morphs could react as described in this case.
sturkwurk posted Sun, 16 June 2013 at 11:42 AM
Quote - It's possible that the M4 expression poses you apply use also morphs from the morph ++ pack. The base M4 without the ++ morphs could react as described in this case.
I've tried both base without the ++ and with the ++ : certain expressions by certan vendors work great - while other expression by other vedors do the opposite with the eyes closing.
sturkwurk posted Sun, 16 June 2013 at 12:13 PM
aha! solved.   The creator of the expressions was using an M4 they bought when it first came out - the close morph was the opposite for the eyes - instead of negative one to close the eyes they had to dial positive one.  They just downloaded and installed a fresh m4 and it fixed the problem.
