Forum: Carrara
Subject: Carrara not recognizing Poser Pro 2014 morphs
diomede opened this issue on Jun 18, 2013 · 7 posts
diomede posted Tue, 18 June 2013 at 5:57 PM
I just installed Poser Pro 2014.  I added its runtime to C 8.5 content tab.  I loaded figures from P2014 runtime, not problem.  However, the morph dials on the parameter tab have no effect.  Thoughts?
MarkBremmer posted Tue, 18 June 2013 at 6:48 PM
Morphs are not always standardized from Poser to Carrara or other plugins that support Poser. Sometimes the morph dials will max out at a certain value However, you can usually manually enter a value instead of spinning the dial and get the results you need.
Let me know what you are working with and I can test with my set-up.
Mark
diomede posted Tue, 18 June 2013 at 8:37 PM
Someone on the Poser forum identified the problem.  Poser's general preferences can be set for external binary morphs.  If a figure is saved to the library with that setting, then Carrara 8.5 Beta won't recognize the morphs in the parameters tab.  If the Poser's general preferences are changed so that the box for external binary morph targets is unchecked, then the morphs will work in Carrara.
Thanks for your quick reply.
Klebnor posted Thu, 20 June 2013 at 12:48 PM
That's not exactly right.  The issue is that Carrara won't use external binary morphs.  The advice in the poser forum, which is correct, was to open the figure in Poser with binary morphs on (checked) then uncheck the box and save.  This forces Poser to save the morphs in the figure.  This saved figure can then be opened in Carrara and saved to the browser with all morphs intact.
Whether the box is checked in Poser or not will have no effect on Carrara.  The figure must be saved with the morphs loaded (and external morphs turned off) and then opened in Carrara.
This is a problem with any poser content with external morphs.
Klebnor
Lotus 123 ~ S-Render ~ OS/2 WARP ~ IBM 8088 / 4.77 Mhz ~ Hercules Ultima graphics, Hitachi 10 MB HDD, 64K RAM, 12 in diagonal CRT Monitor (16 colors / 60 Hz refresh rate), 240 Watt PS, Dual 1.44 MB Floppies, 2 button mouse input device.  Beige horizontal case.  I don't display my unit.
diomede posted Thu, 20 June 2013 at 7:41 PM
Thanks for the clarification. I was getting Amy morphs to work partly deb inadvertentlfloor lowing the correct steps.
Klebnor posted Mon, 24 June 2013 at 12:24 PM
I hate it when things work inadvertentlfloor!
Glad you got it sorted out.
Klebnor
jasmine78888 posted Thu, 04 July 2013 at 1:00 AM
Nice surprise about this shorter form. Can you tell us what it is you are talking/writing about?Has any info. about this shorter form been posted before (and i just missed it)?
jacketpoint http://www.jacketpoint.com/
webdevforums [url=http://www.webdevforums.com]www.webdevforums.com[/url]
test-inside [url=http://www.test-inside.com]test inside[/url]
