darquevision opened this issue on Jun 19, 2013 · 5 posts
darquevision posted Wed, 19 June 2013 at 3:58 AM
i wanted to use mimic and live seemed cool. mimic was supported by poser before but this one you need daz. so i installed daz 4.6 and mimic seemed to install properly but i cant find it.
i checked under tabs in "pose/animation" but didnt see it. looked in the start folder has a folder in that saying "installed plugins" for daz.
i use poser- i have no clue at all about daz, never used it.
basically i can use mimic(normal). just thought it might be fun to do some realtime speaking animations.
any suggestions?
ldgilman posted Wed, 19 June 2013 at 10:07 AM
Did you look in Program Files or Program Files (x86) ??
erzebeth posted Wed, 19 June 2013 at 1:20 PM
yes, check in Program Files or Program Files (x86)
RHaseltine posted Wed, 19 June 2013 at 2:38 PM
Make sure the serial number has been entered, in Help>About Installed plugins. Assuming it is, you may need to switch to one of the less restricted workspaces to get access to the plugin in Window>Panes(Tabs)- Window>Workspace>Select Layout.
darquevision posted Thu, 20 June 2013 at 5:46 AM
cool
thank you for the responses.
i will check it out. and get back to you all.
