ghostship2 opened this issue on Jun 22, 2013 · 5 posts
ghostship2 posted Sat, 22 June 2013 at 6:10 PM
ironsoul posted Sat, 22 June 2013 at 6:35 PM
These are material zones not body parts, the only way I know of exporting material zones from Poser is to use Zbrush and Goz but I would be surprised if no one has developed a script to do this (although I've not found such a script).
ironsoul posted Sat, 22 June 2013 at 6:46 PM
One thought is could you use the group tool to create a prop from the skinface material and then export the prop to get the UVs?
Teyon posted Sat, 22 June 2013 at 6:52 PM
Or you could just export out the head with the lashes, load it into UVMapper, select the lashes and delete them or move them out of the main UV space. Easy Breezy.
ghostship2 posted Sat, 22 June 2013 at 7:25 PM
that worked well. Thanks guys!
