Starkdog opened this issue on Jun 22, 2013 · 10 posts
Starkdog posted Sat, 22 June 2013 at 10:18 PM
Starkdog posted Sat, 22 June 2013 at 10:22 PM
DCArt posted Sat, 22 June 2013 at 10:35 PM
You might want to try this after you conform:
Select the clothing
Choose Figure > Zero Figure (returns the clothing to zero pose)
Choose Edit > Memorize > Figure
Now your figure should be zeroed and memorized and should conform properly. Save to the library.
If this doesn't fix the problem let us know
Starkdog posted Sat, 22 June 2013 at 10:55 PM
That didn't work. I loaded both Miki4 and Miki4 DevRig, and zeroed both. Odd thing, is that Miki4 has a -0.043 translation in the Y-axis, even after zeroing. Before zeroing, she had a 2 degree rotation in the X-axis, and her hip has a 4 degree rotation in the X-axis. This is on a fresh install of Miki4, so I don't know if a ticket is needed at SM, or can I tweak the CR2 file?
Thanks, -Starkdog
DCArt posted Sat, 22 June 2013 at 11:30 PM
Here's what I get with both the dev rig and the finished version of Miki4 both loaded and zeroed
One thing though ... when zeroing Miki4 (the full one, not the dev rig) make sure you have HER selected rather than her eyelashes.
Starkdog posted Sun, 23 June 2013 at 1:47 AM
Starkdog posted Sun, 23 June 2013 at 2:55 AM
MistyLaraCarrara posted Tue, 25 June 2013 at 8:02 AM
what's going on with her left shoulder? back view
DCArt posted Tue, 25 June 2013 at 8:05 AM
MistyLaraCarrara posted Tue, 25 June 2013 at 8:11 AM
kinda looks like a train tunnel.
I've never rendered Miki3 from the rear. now i'm gonna worry until i can go home and test render.
