whystopnow opened this issue on Jun 29, 2013 · 6 posts
whystopnow posted Sat, 29 June 2013 at 10:24 AM
I love the Vanguard spaceship:
http://www.daz3d.com/space/vanguard
Beautiful, detailed interiors and exterior.
However, for the story I'm working on, it's a little small. I'd like to find something like it that has more interior rooms. Maybe twice the size.
So...
(1) Does anyone know of something like Vanguard that is perhaps twice the size?
(2) Another option would be to find a larger exterior-only ship, and then use something like Kibaretto's Powerstar, etc. interiors separately. Strangely, almost all the big spaceship models are for Bryce, 3DS, Carrera, etc. At the moment, I'm only working in Poser and don't own/use anything else for 3D.
Thanks!
ironsoul posted Sat, 29 June 2013 at 11:26 AM
Shaun Williams (Madaboutgames) does large space craft. Not seen anything like a larger version of Kibaretto's Vanguard
Coleman posted Sat, 29 June 2013 at 10:16 PM
Attached Link: Magellan spaceship
About the biggest spaceship model I've seen with an actual interior is the Magellan by PoserWorks. Doors are all fully poseable... but comes at a hefty price.Nightshift3d/Moebius at DAZ also sell a couple Vanguard sized ships with interiors.
jmper4 posted Sat, 29 June 2013 at 10:44 PM
Anything by Skynet3020 in Poser format is awesome.
http://www.renderosity.com/mod/bcs/vendor/skynet3020
The .OBJ models are good as well but the Poser format models have moving parts.
Also this by T. Newton is great. Better still, it's free.
http://www.sharecg.com/v/70075/browse/11/Poser/CRUCERO-SPACE-ARMY
whystopnow posted Sat, 29 June 2013 at 10:58 PM
Quote - About the biggest spaceship model I've seen with an actual interior is the Magellan by PoserWorks. Doors are all fully poseable... but comes at a hefty price.
I actually own Magellan :-)
It's a very nice model, but it does not have nearly the detail of Vanguard on the inside. Most of the rooms are pretty simple textures without the fancy consoles and such that Vanguard is full of...though there are some parts of Vanguard that are not as detailed as I'd like.
I guess story-wise, there are two options:
(1) a single model that is detailed inside and outside. The trick with this is that you are then limited to the rooms in the ship...for Vanguard, for example, you can't suddenly have a new or different room, because the reader has a strong sense of how the small number of rooms connect.
(2) a large external model, and then use some the innumerable "science fiction corridor," "science fiction bridge", etc. scenes for interior shots. The pro to this is that if you decide tomorrow you want an arboretum or a chapel or an engineering bay or whatever, you can do it. The negative is that the rooms may not have a continuity of style and design, at least not without a lot of work. This is sort of the Babylon 5/USS Enterprise TV series method - exterior shots, but the reader has no idea where different rooms go.
I'm starting to think that only (2) is going to give me the level of detail I want inside...
I thank you all for your comments so far.
jmper4 posted Sat, 29 June 2013 at 11:04 PM
#2 is easiest with larger size ships. Continuity is difficult and I find I use interior construction kits by vendors here and there.
Example: 3-D-C (renderosity), Coflek-Gnorg (renderosity), Stonemason (Daz), AntFarm (Daz) has some good spaceship interiors as well.
Also, Coflek-Gnorg set has some expansions at content paradise made by another vendor with Coflek's permission that extends their use even more.
EDIT to add> The expansions for Coflek-Gnorg's sets were created by Meshworks.
