TrekkieGrrrl opened this issue on Jun 30, 2013 · 65 posts
TrekkieGrrrl posted Sun, 30 June 2013 at 4:06 PM
So I brought out Posette :)
And I think she looks rather nice. The eyes are still ... Posette-ish but I smoothed the nose and lips a little with the morph brush and IMO that helped a lot.
So the old figures can still be used, if nothing else then as to serve a point ;)
The texture is one of Ståle Løseth's, not the Vickybuster but another one I found in the deep dark drawers of my P4 runtime L She's wearing the old halterneck dress with BB's nylon shader where I dialed the transparency down a bit. It's still a little see-through, but well G
Any thoughts? :)
(ps the pic looks better in full size, so by all means, give it a little click L)
SamTherapy posted Sun, 30 June 2013 at 4:33 PM
Looks very nice. Proves my point that there's no need to flock to every new figure when it's released because there's life in the old ones yet.
I wouldn't say Posette is the best figure ever but with the right techniques and tools, it's a very useful figure to have around.
Would weightmapping solve the splintery ass problem?
LaurieA posted Sun, 30 June 2013 at 4:39 PM
Weightmapping and a few well-made JCMs probably Sam...lol.
TrekkieGrrrl posted Sun, 30 June 2013 at 4:40 PM
Most likely. I just havent' a clue as to how I go about converting this to a weight mapped figure. I did click "something" that said somethng about convert.. but as I'm not quite sure what weightmapping can and does.. well.. she may be weightmapped not (although I seriously doubt it) but since all I really bend was her arm, and that looked as bad as ever L I dunno if her ass is better now L
I've kinda always liked Posette for female characters... probably because she was my first L
I'm rendering a new version of the pic btw. Because I've tried to subdivide the dress as well, so that may either be an improvement or do nothing at all L I'll post it once it's done.
Oh and btw I "stole" the node setup for her skin from Blackhearted's GND for Alyson. Because I really like the way it looks. And in such cases its really nice that the P4 people is "one map" figures. It makes it so much easier to substitute their skin with other versions, also during a "testing what looks best" phase.
The biggest problem is of course the dire lack of proper hig rez photoreal textures for those old figures. But I have a few, and I'm using them to death L
TrekkieGrrrl posted Sun, 30 June 2013 at 4:44 PM
so here's version 2, where I also dubdivided the dress (x2, the max Poser will do without warning me about lots of polygons L)
Well, much to my surprise, the dress actually looks better non-subdivided.
And even more interesting it "draped"differently (using "draped" in quotation marks because this is a comforming dress) once subdivided. And not necessarily to the better.
So at least in this case, it's a "less is more" thing. But look for yourselves :)
JoePublic posted Sun, 30 June 2013 at 5:59 PM
Modern technologie sure can do a lot for those older figures.
If you want to try out weightmapping, Posette sure would make a great starting project.
Here's a Posette morph I made some time ago, but rendered in PP-2014 using SSS and subdivision.
ssgbryan posted Mon, 01 July 2013 at 1:58 AM
Quote - > Quote -
In Poser 2014, weight mapping is a 1-click operation.
Go to the Menu Bar - Figure - Merge all zones to weight maps.
That is all there is to it.
I weight mapped every figure I own in less time than it took me to weight map Rikishi in PP 2012.
As far as the "splintery ass problem" - neither weighmapping or subdivision appear to address everything. I weight mapped Posette & went to "3" on the subdivision for the entire figure (I don't recommend this without serious horsepower & memory.)
The glutes are not anywhere near as "lumpy", but you would still need to spend time with the smoothing brush.
If someone make high rez meshes for older figures, I'd buy them in a heartbeat - with weight mapping,the morph brushes, and the fitting room, all of those characters are viable again.
Thanks to those 3 items, I now have Eroko working the brig in my Trek fan fiction - she works quite well at subdivision 2 for the head, neck, chest & collars.
PhilC posted Mon, 01 July 2013 at 3:04 AM
Point well made :)
JoePublic posted Mon, 01 July 2013 at 4:47 AM
That "Merge All Zones to Weightmaps" button is complete nonsense.
All it does is do the raw "conversion" which only makes the cr2 bigger without adding any bending benefit.
"Weightmapping" a figure means to make use of the better granularity weightmaps can provide by carefully editing weight-and bulgemaps.
Basically you have to re-rig the figure from scratch as the only thing you can keep from the old rigging are the joint centers.
And it's a good idea to only "merge" those joints to weightmaps you actually plan to rig, because that way the cr2 will be smaller and load faster.
So, do not simply "convert" your figures to "weightmaps".
It will give you zero benefit and actually harm their performance.
Do the conversion joint by joint while you edit the weightmaps.
nobodyinparticular posted Mon, 01 July 2013 at 5:27 AM
I tried the "one click" method shortly after I got PP 2014. I agree, I didn't see any real improvement. Are there any good tutorials on proper weight mapping? I've been using a number of older characters. Been trying to rid myself of the V4 habit. Rather successfully so far.
-Timberwolf- posted Mon, 01 July 2013 at 6:44 AM
@JoePublic: darn, where is the "Like" button, when you urgently need one.
PhilC posted Mon, 01 July 2013 at 7:21 AM
I use the "one click" just to provide me with a starting point for weight mapping then fine tune each joint as required.
randym77 posted Mon, 01 July 2013 at 7:22 AM
Dang. I'd hardly recognize ol' Posette. Makes me want to dust her off and try her in modern Poser. Very nice work!
JoePublic posted Mon, 01 July 2013 at 8:14 AM
"I use the "one click" just to provide me with a starting point for weight mapping then fine tune each joint as required."
@PhilC:
Yes, but unless you plan to edit each and any joint, this does more harm than good as a weightmap uses up more space than a spherical falloff zone.
Fingers are usually perfectly ok, so there is not much need to weightmap them.
So the "one click" button just adds 30 additional weightmaps to the figure that aren't really needed.
As a unedited weightmap gives no bending improvement whatsoever over conventional rigging, this is no actual "starting point" either.
All it does is saving you the three mouseclicks you need to merge the falloff zones directly in the joint editor.
It's convenient, but it creates weightmaps that aren't needed.
And it confuses beginners by suggesting that PP-2014 could "auto-weightmap" every figure for you with a single click.
The "merge all zones at once" functionality is actually needed for some scripts, but exposing it in the GUI is a mistake.
But I can only explain and demonstrate. What people do with their copy of Poser is their own buisiness.
@nobodyinparticular : Sorry, no tuts what I know of except the videos on YouTube. My suggetion would be, the more comfortable you are with using the MorphBrush, the easier weightmapping will be for you.
@-Timberwolf- : Thanks !
@TrekkieGrrrl : May I suggest to use SnarlyGribbly's EZSkin to generate proper SSS shaders ?
Or manually edit the scatter-zones to avoid the "SSS-Blueing" of the mouth and other bodyparts.
Whenever two parts of the mesh with the same scatter-zone number are in close contact, the SSS-algorithm adds a blue tinge.
This can easily be avoided by assigning different scatter-zone numbers.
lmckenzie posted Mon, 01 July 2013 at 8:41 AM
Looking good. There should be enough Posette remaps out there to help with the texture situation.
EnglishBob posted Mon, 01 July 2013 at 8:59 AM
The Poser 4 clothing is made rather differently from modern stuff. In particular, they're "solid", and the back of the halterneck is filled in with long, thin triangles, which may possibly be related to your subdivision problems?
Posette is looking good, indeed; although I bet her super-long thighs are not so easy to fix. :)
TrekkieGrrrl posted Mon, 01 July 2013 at 3:21 PM
Joe Public: I love that face morph you made there. Is it available anywhere? (read: I WANT IT! ;)) Also what texture is that?
Posette remaps? Where? What? How?
As for EZSkin, it just tells me that Posette is an unsupported character. And since I have no idea of how the script works, I do not know how to add a new figure (just as I never figured out how to add another figure to VSS)
And that was why I simply "borrowed" Blackhearted's node setup from GND Anastacia and manually swapped all the material references with the right texture. I don't know how Blackhearted made his setup, but so far I prefer it to both VSS and (what I've managed to make with) EZSkin.
Then again.. I'm good at copying and pasting ;) And not good at understanding the reasons why a certain node is wired the way it is. It's math. And math makes my brain run away and hide.
Everybody is praising EZSkin, so I'm SURE it's just me using it wrong... But as I have no idea of what do change (or in this case, how to tell it to apply its magic to Posette) I'm in the dark. So I "cheat" and borrow from whatever looks nice ;)
EnglishBob posted Mon, 01 July 2013 at 3:45 PM
Attached Link: http://shop.aprilsvanity.com/-free-items/remaps/cat_22.html
> Quote - Posette remaps? Where? What? How?Here. :-)
Edited to add: David Hoadley's Posette remap to take V3 textures.
TrekkieGrrrl posted Mon, 01 July 2013 at 4:07 PM
Awesome! Thanks, EnglishBob :D
Heh and I think I have some of them. While I was searching through my textures folder, "AprilsVanity" did ring a bell... I should hae gone with my hunch an checked that folder it seems :D
mylemonblue posted Mon, 01 July 2013 at 4:44 PM
TrekkieGrrrl your posette looks fantastic.
EnglishBob thanks for those links. I still find posette very useful as well.
My brain is just a toy box filled with weird things
JoePublic posted Mon, 01 July 2013 at 5:20 PM
Thanks Trekkie.
It's DPHoadley's V3 remapped Posette and the texture is based on Goldtassel's "Millenium Dollar Baby", but it's modified quite a bit.
You can edit EZSkin to add figures, but of course "copy and paste" is fine, too.
You just have to enter the material room and find the scatter node.
Make sure that teeth and eyes have different scatter group numbers assigned than the skin. For example if skin is #1, then teeth should be #2, eyeballs#3, nails #4, etc.
Most older SSS shaders don't do that, so you get the "blueing".
As for the head morph, I sent you a sitemail.
Gremalkyn posted Mon, 01 July 2013 at 8:05 PM
Quote - > Quote - Posette remaps? Where? What? How?
Here. :-)
Here is DPH's PosetteV3wG if you want a more anatomically correct version. I do not have it yet, even though it is free.
http://www.renderosity.com/mod/freestuff/details.php?item_id=43397
(Checking the Nudity box just because of the nature of the item - no nude image for the thumb.)
lmckenzie posted Tue, 02 July 2013 at 4:11 AM
There's also Piktlad's great Nea, a Posette based figure who takes V2 maps. I seem to have a vague memory of a V3 mapping for her but maybe not. There's also Zenon, her P4M based counterpart.
Posette Forever still seems to alive and rocking it Old School - where else are you going to find a new head morph for the Nude Boy?
Long after the sun has set on Dawn, Genesis has turned to Revelation and Roxy's a forgotten doxy, Posette will still be there.
"Posette'll be all around in the dark - Posette'll be everywhere. Wherever you can look - wherever there's a fight, so hungry people can eat, Posette'll be there. Wherever there's a cop beatin' up a guy, Posette'll be there. Posette'll be in the way guys yell when they're mad. Posette'll be in the way kids laugh when they're hungry and they know supper's ready, and when the people are eatin' the stuff they raise and livin' in the houses they build - Posette'll be there, too." - With apologies to Steinbeck, Stewart and myself for quoting myself:
http://www.planit3d.com/source/poser/narcissus1.html
http://www.posetteforever.com/
Eric Walters posted Tue, 02 July 2013 at 11:56 PM
Cool! Where is our Posette stalwart- DPHoadley?
Stale Loseth! OMG! He was an early hero of mine.
Quote - All this talk about high- and low resolution combined with PP2014's subdivision feature made me curious to see what could be done with some of the legacy Poser stuff.
The texture is one of Ståle Løseth's, not the Vickybuster but another one I found in the deep dark drawers of my P4 runtime L She's wearing the old halterneck dress with BB's nylon shader where I dialed the transparency down a bit. It's still a little see-through, but well GAny thoughts? :)
Eric Walters posted Tue, 02 July 2013 at 11:59 PM
HAHA! Thanks-even without intentional Jocularum- you made me laugh.
I had forgotten that before the various issues with the V's there was the heartbreak of splintery ass!
Quote - Would weightmapping solve the splintery ass problem?
TrekkieGrrrl posted Wed, 03 July 2013 at 6:50 AM
Quote - There's also Piktlad's great Nea, a Posette based figure who takes V2 maps. I seem to have a vague memory of a V3 mapping for her but maybe not. There's also Zenon, her P4M based counterpart.
Right! I'd completely forgotten Nea. And she IS truly a very nice figure :)
Looks like I should go hunting in the dark nooks and crannies of my trusty old runtime :D
The old figures renders fast, even with all the bells and whistles and subD. And they have zillions and zillions of canned poses made exatly for them
MistyLaraCarrara posted Wed, 03 July 2013 at 9:00 AM
Quote - Thanks Trekkie.
scatter group numbers?
over the weekend, i found some light sets don't play nice with sss, the figure renders inked out black. Could it be the specular only light is the guilty?
dphoadley posted Wed, 03 July 2013 at 8:10 PM
Here is the genital version of my PosetteV3 remap! This is the only version of Posette that I use nowadays. If anyone wants the regular PosetteV3 remap, then send me an email to dphoadley2@yahoo.com.
I don't do much with Poser nowadays, as my last partner up and quite on me very abruptly, cut off all contact with my, right in the middle of a project, that I just lost heart in doing anything!
dph
LaurieA posted Wed, 03 July 2013 at 8:49 PM
That's quite a 70's bush she's got going
lmckenzie posted Wed, 03 July 2013 at 11:05 PM
Thanks for the link DP - I was disappointed when the other one was dead.
"That's quite a 70's bush she's got going"
LOL, gone like much of the rain forest. I'm sure historians will weigh in on the odd cultural shift. Musta been the teeny bikini thing I guess.
dphoadley posted Wed, 03 July 2013 at 11:32 PM
I LIKE BUSH!!!
Both the guy who took down Saddam Hussein, and the natural hair of the Delta of Venus!! Pity that I couldn't do the same with her arm pits that I did lower down!!
LaurieA posted Wed, 03 July 2013 at 11:54 PM
Her ampits??? Really??!! o.O
OMG...that's gross, sorry. LOL.
dphoadley posted Thu, 04 July 2013 at 3:44 AM
Quote - Her ampits??? Really??!! o.O OMG...that's gross, sorry. LOL.
What can I say, I find Natural women sexy!!
LaurieA posted Thu, 04 July 2013 at 8:06 AM
Well...I'm a girl ;). And I wouldn't be caught dead with fuzzy pits...of course, if I was dead I don't think I'd much care, do you? Hahaha :P
You're not the first person to like body hair on a female. I guess I just don't understand it...gah - anymore than I understand a guy wanting to get rid of all of his body hair (that's REALLY icky) LOL.
RedPhantom posted Thu, 04 July 2013 at 8:19 AM Site Admin
I think Guy as well as gals should shave their pits. I can't tell you how many times I've seen a guy raise his arms and the hair antipersperant is all clumped in the hair. You can't tell me that it works like that.
I imagine though that you could get armpit hair in the hair room pretty easily.
LaurieA posted Thu, 04 July 2013 at 8:20 AM
Yep, I think the hair room would be the way to go with the armpit fur DP. LOL I've done it with Mikey already ;).
dphoadley posted Thu, 04 July 2013 at 9:03 AM
Quote - I think Guy as well as gals should shave their pits. I can't tell you how many times I've seen a guy raise his arms and the hair antipersperant is all clumped in the hair. You can't tell me that it works like that. I imagine though that you could get armpit hair in the hair room pretty easily.
I live in Israel! What's an antipersperant? Here we tend to rely on the HOT DRY AIR off the Saudi Arabian to remove our sweat!!
Frankly, I haven't used deoderant for the last 45 years! And truthfully, I don't notce such smells anymore! What I do notice at times, is the stench that those who do use deoderant seem to have! Very unpleasnat!
And frankly, I like my HAIRY wife just as she IS!!! -but she's a redhead, so it doesn't show so much!!
LaurieA posted Thu, 04 July 2013 at 9:12 AM
o.O
dphoadley posted Thu, 04 July 2013 at 10:41 AM
Attached Link: Two Nudes in a Garden by a Wall
For another example of a 'Blast from the Past', here's an example of my V3 remap of P5 Judy.Quote - My remapped P5 Judy with V3 skins! Not so 'Butt Ugly' after all.
This is Antonia and Fedosya for Judy by Ken1. The skins are V3 textures that I've had for awhile. Background is Cyclorama, coupled with a homemade bump map, that I set to a value of 10 to pop out the vines, etc.
Antonia's hair is Saphire Fox by Quarker, and Fedosya's is Evo Long by Kozaboro. The bench is from a Medieval Tavern.
dphoadley posted Thu, 04 July 2013 at 11:42 AM
Attached Link: Three Naked Sisters
Three sisters seek comfort from each other after discovering that they are each in the family way.Guess which figures I used. (Hint: V3, PosetteV3, remapped Victoria4V3)!!!
Skin texture is EL's Odetta.
Evo Long Hair for V3 from Kozaburo.
The poses are all adaptations of karen1573's Very Vicky collection, donated to freestuff.
Rendered in Poser 5; background was applaid in Photoshop, with very minor postwork.
Enjoy!
The point I wanted to make here, was that when the texturing is all the same quality, there is very little noticable difference between the posed figures!
dphoadley posted Thu, 04 July 2013 at 11:46 AM
Attached Link: Three Naked Sisters.02
A continuation and elaboration on the theme of my previous upload. Enjoy!Gremalkyn posted Thu, 04 July 2013 at 12:38 PM
Quote - P4 Posette with genitals remapped to take V3 skins: http://www.sharecg.com/v/24514/browse/5/3D-Model/PosetteV3wG-PosetteV3-with-GenitalsHere is the genital version of my PosetteV3 remap! This is the only version of Posette that I use nowadays. If anyone wants the regular PosetteV3 remap, then send me an email to dphoadley2@yahoo.com.
dph
Sorry your partner disappeared. Hope it is nothing serious.
As to the product, how does it compare from a technical standpoint with your PosetteV3wG (PosetteV3 with Genitals) found here?
I do not have either of them yet - is there a need to get both, or is the one at ShareCG "new and improved?" If so, how?
dphoadley posted Thu, 04 July 2013 at 1:43 PM
Attached Link: Just Another Receptacle?
Women are NOT just another receptacle, but the very souce of life itself. Without them, life would be extremely boring. DPHArduino's Sophia P4WWG Cr2 hacked by me to my PosetteV3wG. Mylocha hair and Panko's Viet Cong V3 skin texture. Background is a Daz Curtain prop, and various vases, some of them freebies, and some not.
Quote - Sorry your partner disappeared. Hope it is nothing serious.
It was more than serious, it was devastating! -especially as it was abrupt, and without any discussion whatsoever on possible solutions as to whatever may have been wrong! To this day, I still haven't a clue as to what might have caused the rift!
Quote - As to the product, how does it compare from a technical standpoint with your PosetteV3wG (PosetteV3 with Genitals) found here?
PosetteV3, without genitals, is my 1st remap of Posette. PosetteV3wG has a long history. The Posette Genital figure was originally created by Hellborn for the Poser 3 version of Posette. He took the hip, and added a nuber of facets so as to create a cleft, outer and inner left & right labia, and a clitoris. He also created a small anus. Someone took this hip, cut out the gentials, and then spliced them into the Poser 4 Posette's hip. Somehow, they also managed to transfer the morphs that work the various parts of the genital, thus giving Posette a working 'Whatsit'!
The drawback to this is that NONE of Posette's 'regualr' hip morph will work with this version of Posette! ALL OTHER MORPHS WILL, BUT NOT THOSE OF THE HIP!!!!!
Thus, Pitklad's Nea morphs will work on PosetteV3wG will work on her fore every OTHER body part, (Breasts, abdomen, thighs, shins, fingernails, toes, etc.) but not the hip. But the morphs that DO work on the hip are those that open and close the vagina, the anus, lengthen the clitoris, spread the labia, etc.
So, it's a trade off, working whatsit, or more morphable hip shape. You take your choice! Myself, I like her hip just as it is, and prefer to have the working whatsit!!!
dph
dphoadley posted Thu, 04 July 2013 at 1:55 PM
Attached Link: Angelique
Angelique morth form somewhere. Base figure is PosetteV3wG by dphoadley. Lighting is SoCalRoberta's new freebie lite set in Freestuff. T-Shirt texture can be found in my Freestuff. Rendered in Poser 5, and postworked in Photoshop with background, gradient, and lighting effect filter added.Gremalkyn posted Thu, 04 July 2013 at 3:52 PM
Quote - So, it's a trade off, working whatsit, or more morphable hip shape. You take your choice! Myself, I like her hip just as it is, and prefer to have the working whatsit!!! dph
I will probably get both, then, as I have no plans to use a working whatsit but might later on.
dphoadley posted Thu, 04 July 2013 at 3:59 PM
SamTherapy posted Thu, 04 July 2013 at 4:30 PM
Hairy women :barf:
TBH, I don't even care for a landing strip nowadays. Besides which, I don't like impersonating a cat* after spending some quality time with a lady.
dphoadley posted Thu, 04 July 2013 at 5:08 PM
Quote - Besides which, I don't like impersonating a cat* after spending some quality time with a lady.
I don't know, I never had any problem with furballs! -in fact, I found them rather tasty!
SamTherapy posted Thu, 04 July 2013 at 7:57 PM
David, you're one of the world's really good guys but there are times when you're too gross for words. :D
lmckenzie posted Thu, 04 July 2013 at 10:10 PM
No offense DPH and I know I shouldn't ask but cudja knock back the fontsize on your political statement to something a bit less real estate intensive. I know, I'll go away.
dphoadley posted Thu, 04 July 2013 at 10:13 PM
Hey, Sam, you're the one who called into question as to whether my wife, in her pristine state of nature, was a lady or not!! -as for impersonating a cat, what else was I supposed to assume? -licking fur, playing cat&mouse with danglely objects, finding new and engenious ways to open my kitchen cabinets and steal snacks*?
*my pet cat actually DOES that!!!
SamTherapy posted Fri, 05 July 2013 at 8:52 AM
pitklad posted Sat, 06 July 2013 at 7:13 PM
lmckenzie thanks for rembering Nea and Zenon, I'm glad you find those usefull
The latest Nea version is 2.12 and she is located here:
Here is a simple portrait of her on PP12 using EZskin
WandW posted Sat, 06 July 2013 at 7:34 PM
"Oh - the manual says that? I have never read the manual - this must be why."WandW posted Sat, 06 July 2013 at 7:50 PM
"Oh - the manual says that? I have never read the manual - this must be why."JoePublic posted Sun, 07 July 2013 at 6:22 AM
Here are some renders I did last year.
Might as well re-post them.
First P5 Judy.
JoePublic posted Sun, 07 July 2013 at 6:24 AM
JoePublic posted Sun, 07 July 2013 at 6:27 AM
JoePublic posted Sun, 07 July 2013 at 6:29 AM
JoePublic posted Sun, 07 July 2013 at 6:30 AM
JoePublic posted Sun, 07 July 2013 at 6:34 AM
JoePublic posted Sun, 07 July 2013 at 10:21 AM
Soo. I rummaged through my old Poser 4 Runtime and unearthed Stahlratte's Valeri-V3, a Nea-V3 Hybrid using V2 mapping.
Transferred the weightmapped rigging from my V3WM over to her and made some new shaders for the old Zrincx V2 texture.
Excuse the unsettling big smile, but I wanted to show the teeth shaders.
Rendered in PP-2014 with SubD on for the figure and the hair.
pitklad posted Sun, 07 July 2013 at 10:52 AM
lmckenzie posted Wed, 10 July 2013 at 9:24 AM
"And one more time my own face morph for Posette. "
And a very pretty Posette indeed.
Thanks Pitklad for the link to the new Nea. I see that Jon Malis has put up a free item recently. His dwarves for the P4 figures were great. Lost of forgotten things out there that could be dusted off. One of the reasons it would be nice to have a permanent home for things that eventually end up disappearing - alas often discussed but never came to pass.
MartinW posted Thu, 11 July 2013 at 1:39 AM
Anyone remember the old Nene figure?
Thorne's Tisa I remember was good too.
Anyone know if they're around to dload? Be interesting to see them re-skinned and rendered in a more modern Poser (think I last had/rendered them in P4!)
