Ninja-G33k opened this issue on Jul 04, 2013 · 5 posts
Ninja-G33k posted Thu, 04 July 2013 at 5:40 PM
Greetings, all!
I am a complete n00b to Poser; I bought Poser Debut to introduce myself to things, but the learning curve has been a trifle steep.
My default 3D program is DAZ Studio, and I have a number of Poser props with associated PMD files, so of course the morphs in those files don't work with DAZ.
I've tried using the PMD Injector plug-in as a workaround, going so far as to attempt to write a PZ2 file that the injector can use, but the morphs for this prop don't inject.
I pulled the prop into Debut, where the morphs work, but I wonder if there's a way to save/export/whatever the PP2 such that the PMD file isn't required the for the morphs to work, so I can use it in DS.
Any help is greatly appreciated.
Thanks!
Ninja-G33k posted Thu, 04 July 2013 at 6:04 PM
I am blind!
I just discovered the "Helping Newbies" sticky thread, and have copied this post there.
Mods, please delete this thread.
dphoadley posted Thu, 04 July 2013 at 6:05 PM
PhilC posted Thu, 04 July 2013 at 8:17 PM
Go to the Poser preferences under the Edit menu and un-select the option to save external morph binary data. The morph data will then get saved within the file when you save it back to the Poser library.
Ninja-G33k posted Thu, 04 July 2013 at 10:03 PM
Quote - Go to the Poser preferences under the Edit menu and un-select the option to save external morph binary data. The morph data will then get saved within the file when you save it back to the Poser library.
Thanks much! After I made that second post I went back and wrestled with Debut for a while and wound up discovering that checkbox under the Edit menu.
I've gotten about a dozen things fixed now. :-D
