Subject: PP2014 preview settings, can i see yours?
jonnybode opened this issue on Jul 09, 2013 · 16 posts
jonnybode posted Tue, 09 July 2013 at 1:53 PM
Hi!
Poser Pro 2014 (click picture for full view)
The shadows in my preview looks really weird, do yours look any better?
I have a Geforce GTX 660 graphic card but i dont know if that is the problem, maybe my settings in Poser are all wrong.
wimvdb posted Tue, 09 July 2013 at 2:29 PM
Increase Preview Shadow Map Size in the properties of the light
TrekkieGrrrl posted Tue, 09 July 2013 at 3:33 PM
Wim, this is the preview, not a render, so the shadow map likely won't do a thing.
I don't have Hardware shading or -shadows on. I'll try turning it on and see if mine looks like that
caisson posted Tue, 09 July 2013 at 3:45 PM
Changing the Shadow Map Preview Size - which defaults to 512 and will go up to 4096 - does improve the look of shadows in the preview window on my system :)
Not approved by Scarfolk Council. For more information please reread. Or visit my local shop.
bagginsbill posted Tue, 09 July 2013 at 3:52 PM
Quote - Wim, this is the preview, not a render, so the shadow map likely won't do a thing.
Look again at the original picture. On the left. "Preview Shadow Map Size" and it absolutely will affect the preview shadow. This is PP2014 - new features.
wimvdb posted Tue, 09 July 2013 at 3:57 PM
As the others said - that settings defines the size of the shadow maps in preview - like Preview Texture resolution does for textures in the Render Settings for Preview
Not sure which version it was introduced
TrekkieGrrrl posted Tue, 09 July 2013 at 5:14 PM
Ah duh! As I hadn't used the hardware shading myself (until now) I'd missed that little thing.
so the preview shadows use a shadow map? Live and learn :D
3Dave posted Tue, 09 July 2013 at 7:32 PM
Thanks for that, a feature I had n't spotted, on a related topic is there a "Force 2-sided" option available for preview/comic book tone renders?
wimvdb posted Tue, 09 July 2013 at 8:01 PM
Quote - Thanks for that, a feature I had n't spotted, on a related topic is there a "Force 2-sided" option available for preview/comic book tone renders?
Remove backfacing polygons in the Preview Render Settings should do that trick
jonnybode posted Tue, 09 July 2013 at 10:19 PM
Hi!
quote from Wimvdb:  Increase Preview Shadow Map Size in the properties of the light
Thank you, that did indead solve the problem with the "blocky" look on the shadows.
Im still not fully satisfied, if one looks at the face and the position of the light i dont understand why there are black spots in the face (one light in scene).
I have increased the depth bias (in preview tab)  to 1000 but they still wont go away, it gets better but nod good.
And thank you to the other posters for their input in this matter
R_Hatch posted Wed, 10 July 2013 at 1:11 AM
Point lights will not yield desirable results in the preview, no matter how high you set the shadowmap size. Use either Infinite or Spot lights instead.
3Dave posted Wed, 10 July 2013 at 3:02 AM
Quote - > Quote - Thanks for that, a feature I had n't spotted, on a related topic is there a "Force 2-sided" option available for preview/comic book tone renders?
Got it, Many thanks!
jonnybode posted Wed, 10 July 2013 at 9:47 AM
Quote from R_Hatch
I see, indeed you are right!
Point light has been my "weapon of choise" for years now, guess its time to go back to the old spots again :-)
Thank you!
moogal posted Thu, 11 July 2013 at 6:31 PM
> Quote - Point lights will not yield desirable results in the preview, no matter how high you set the shadowmap size. Use either Infinite or Spot lights instead.
Not so sure I agree.  The shadows from the point light in this image look pretty good to me (except the one sided ruler prop doesn't cast any unless turned away from the light at which point it can't be seen).
moogal posted Tue, 16 July 2013 at 6:58 PM
Upon further investigation, it looks as if I may have found the only effective use conditions for the pointlight in preview.  My image looks OK because while the surface casting the shadow is complex, the surfaces receiving the shadow are both flat.  I added a point light to a more complex scene containing actual props and the result are not so good...  That tells me Poser has no trouble creating a shadow volume from a point light, but then is not so good at determining what parts of other objects are within the shadow.
jonnybode posted Tue, 16 July 2013 at 10:29 PM
I see..
Have decided to stick with point lights, just have to live without shadows in preview mode.
