xpdev opened this issue on Jul 16, 2013 · 14 posts
xpdev posted Tue, 16 July 2013 at 7:32 AM
The only light in the sun (150%)
Sky outside is a dome but not visible in raytracing and no light emitter.
I checked all the materials in the room, but I did not find anything strange.
Do you recommend?
Thank you.
Poser Pro 2014 SR 1 on Windows 7 64
bit
I use IDL, Gamma Correction and EZSkin for all
final renders.
xpdev posted Tue, 16 July 2013 at 7:33 AM
bit
final renders.
bit
final renders.
bit
final renders.
ironsoul posted Tue, 16 July 2013 at 12:09 PM
Try increasing the indirect light quality.
ErickL88 posted Tue, 16 July 2013 at 12:40 PM
IIRC, by switching off Irradiance Cache (for IDL), you can avoid these splotches. But it tremendously will increase render times.
I haven't read anything that this got better with PP2014 tho.
xpdev posted Tue, 16 July 2013 at 12:40 PM
Done, the same shadow problem.
bit
final renders.
primorge posted Tue, 16 July 2013 at 1:53 PM
Yeah, BB suggested switching off IC to eliminate those artifacts... See this thread.
xpdev posted Tue, 16 July 2013 at 2:34 PM
i have made this test this mornig primorge, but render time is very very very long....
and the room is empty....
bit
final renders.
hborre posted Tue, 16 July 2013 at 3:17 PM
Your pixel sampling seems rather high.
luckybears posted Tue, 16 July 2013 at 3:51 PM
Yje image is lit by tqo panels with an ambient value of 10.
The artifact is not evident o the red cube but it does show a little on the plane it's resting on, not so much as with the cube that is the same colour as the floor though
xpdev posted Wed, 17 July 2013 at 2:13 AM
bit
final renders.
hborre posted Wed, 17 July 2013 at 10:49 AM
You can still see them at the far wall where it meets the floor. But better.
primorge posted Wed, 17 July 2013 at 11:00 AM
Does look better... hborre is right also about your pixel samples. I'd say samples of 8 is the highest range for quality that I would go, many would think that 8 is too high. That's definitely contributing to the render time.
