rokket opened this issue on Jul 19, 2013 · 36 posts
rokket posted Fri, 19 July 2013 at 11:11 PM
If I have to create that mesh I will, but I was hoping there was a way around it.
For the record, I am NOT making a Green Lantern, only trying to use that aura effect on another character.
ghonma posted Sat, 20 July 2013 at 12:40 AM
Is there any reason you can't use an image editor for this ? Cause it's real easy to do there and looks much nicer besides...
rokket posted Sat, 20 July 2013 at 1:02 AM
Quote - Is there any reason you can't use an image editor for this ? Cause it's real easy to do there and looks much nicer besides...
Yeah, I could, but I want to be able to do it in Poser. As I stated above, I know one way to do it, I was just wondering if there were other ways to get it done.
aRtBee posted Sat, 20 July 2013 at 1:23 AM
just thinking out loud, Ambient produces an even surface lighting, and Diffuse produces brigtness in the middle and darness at the sides, so Ambient minus Diffuse might be something in the right direction.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
ghonma posted Sat, 20 July 2013 at 1:38 AM
I don't think you can solve this with shading alone since shading only applies where there is a mesh. The bright outline in the mesh could possibly be done with an edge blend but the glow going beyond the mesh needs to be done either at a 2D level (in post) or else you have to provide a mesh to support it.
Maybe the art lens method of BB would work though i'm not sure how you would do the blur.
ironsoul posted Sat, 20 July 2013 at 1:43 AM
ironsoul posted Sat, 20 July 2013 at 2:59 AM
seachnasaigh posted Sat, 20 July 2013 at 4:53 AM
"I know this effect can be done in Poser..."
Oh, yeah; I'd bet money that it can be done.
Creating a poseable surrounding aura is not a trivial task; Rokket wisely realizes this.
An alternative -which I have not tried- would be to use a duplicate doll parented/conformed to the main doll. Set materials for things like inner mouth, etc. to be invisible. For the outer surface (exposed skin, clothes, hair), try adding a constant* and fairly large displacement (this gives you an envelope) and use the ambient edge blend as the texture. Worth a try.
* If the outfit is a "second skin" displacement & texture applied to the doll's skin, then just add the second skin displacement to the constant displacement.
OSes: Win7Prox64, Win7Ultx64
LaurieA posted Sat, 20 July 2013 at 7:53 AM
I was thinking what ironsoul did - edge blend ;).
seachnasaigh posted Sat, 20 July 2013 at 8:51 AM
Agreed, as long as you don't require that the glow extend outside of the doll's silhouette, ironsoul's idea is simple and elegant.
BionicRooster posted Sat, 20 July 2013 at 11:59 AM Forum Moderator
Poser 10
Octane Render
Wings 3D
SamTherapy posted Sat, 20 July 2013 at 12:17 PM
Would it also be possible to make the figures Emitters and use Atmosphere?
BionicRooster posted Sat, 20 July 2013 at 12:25 PM Forum Moderator
Well enabling IDL would turn them into emitters just by adding the ambient edge blend, and yes, if you can tolerate the render time hit, you can add some atmosphere to possibly get the glow around them, or at least, one would think.
Poser 10
Octane Render
Wings 3D
BionicRooster posted Sat, 20 July 2013 at 12:34 PM Forum Moderator
Upon experimenting, I'm not so sure it would work now, not getting results I thought.
But in postwork, you could easily do it.
Poser 10
Octane Render
Wings 3D
rokket posted Sat, 20 July 2013 at 1:32 PM
I like where this is headed. Both Bionic Rooster and ironsoul gave me some really good points to start.
And seachnasaigh, your idea of the doll parented to the figure might work too. What I was thinking was to increase the scale, but with your double edge node technique, you probably don't have to.
Time to do some tinkering.
rokket posted Sat, 20 July 2013 at 1:35 PM
Quote - Upon experimenting, I'm not so sure it would work now, not getting results I thought.
I wanted to avoid doing it post because it doesn't look right when they have a prop in their hand, or are touching a prop or another figure in the scene. It makes it hard to get it right. Making a 2D glow on a 3D object and getting it to look like it was supposed to be there is a lot of work. I am sure the long render time vs what I would have to do in postwork is a pretty good trade off.
Tecknophyle posted Sat, 20 July 2013 at 2:26 PM
(No postwork)
TrekkieGrrrl posted Sat, 20 July 2013 at 2:41 PM
There was a thread a long time ago about Bioluminicense. Back when the Gather Node was new IIRC...
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2217752&page=1
ghostship2 posted Sat, 20 July 2013 at 4:33 PM
On Ironsoul's example set Transparency_Edge to 1 and Transparency_falloff to .5 or something and you get a cool x-ray effect.
rokket posted Sat, 20 July 2013 at 4:51 PM
Quote - You want to do something like this, yes?
(No postwork)
Yes.
moogal posted Sat, 20 July 2013 at 7:44 PM
I don't know if you are trying to avoid post work for the challenge or to keep the process simple... But if you want the aura to extend beyond the filter, I have created a few filter setups for virtualdub to do bloom.
The idea is that you need to keep the aura brighter that anything else in the scene (or those things will glow also). First you load the image in and crank the contrast up until only your aura remains visible against a black background. It appears I used the threshold filter to do this. Then you apply a gaussian blur, and use filterblender to add the aura to the original image.
Attached is the setup of one that worked well for putting an aura around an overhead lightglobe. Not sure if that one adds chroma or just luma, but it shows how the process works.
rokket posted Sat, 20 July 2013 at 8:30 PM
I am doing this so that I don't have to post work. I am looking for a good way to get this done in poser. I am sure I have a good method, I just have to experiment with it.
BionicRooster posted Sat, 20 July 2013 at 8:36 PM Forum Moderator
once you figure out a method, please share with the rest of us. Enquiring minds wanna know.
Poser 10
Octane Render
Wings 3D
rokket posted Sat, 20 July 2013 at 8:49 PM
Quote - once you figure out a method, please share with the rest of us. Enquiring minds wanna know.
You bet I will. I'll post the render and the mat room screenshot in this thread.
JimTS posted Sat, 20 July 2013 at 9:25 PM
Shader Woorks
http://www.runtimedna.com/Utilities-Vol4-Ghost.html
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
rokket posted Sat, 20 July 2013 at 10:30 PM
Thanks, but I don't buy things. That's why I am trying to learn everything. I can't buy it.
ironsoul posted Sun, 21 July 2013 at 10:59 AM
Edge blend - no
Lens effect - nope
gather - hum, no
displacement - nope
Displacment edge blend - ugh
hair - stupid idea
hair edge blend - even more stupid idea
dof - dissapointed
beer - hmm
more beer - starting to look good.
even more beer - yep that worked.
aRtBee posted Sun, 21 July 2013 at 11:04 AM
so we need a beer shader :)
SamTherapy posted Sun, 21 July 2013 at 11:11 AM
A Single malt, cask strength, non chill-filtered Scotch Whisky shader would be even better. :)
rokket posted Sun, 21 July 2013 at 12:05 PM
Yeah, it looks like I am going to have to model a mesh around the figure and use the double edge blend technique. Most of the attempts I made at it resulted in the figure looking like they were bathed in harsh light.
No shortcuts here. Dang it.
@ Sam Therapy: pass that single malt my way when you get a chance.
SamTherapy posted Sun, 21 July 2013 at 12:20 PM
@ rokket: If you are ever in the vicinity, I will be happy to share a bottle with you.
rokket posted Sun, 21 July 2013 at 12:46 PM
I am a merchant seaman and world traveler. If I know the vicinity, I'd more than likely tell you when I will be there. I don't get over to Europe too much, but I do get there.
SamTherapy posted Sun, 21 July 2013 at 4:03 PM
Tells you where I am in my avatar. Wath Upon Dearne is a village near Rotherham and Barnsley. Despite all that, it's a nice place. :)
We don't get too much shipping around here, though. :D
rokket posted Sun, 21 July 2013 at 4:12 PM
Quote - Tells you where I am in my avatar. Wath Upon Dearne is a village near Rotherham and Barnsley. Despite all that, it's a nice place. :)
Yeah, and usually when I am in the country, I don't get off the coast too far.
SamTherapy posted Sun, 21 July 2013 at 4:30 PM
Given that England is only about as big as Kansas, we're about an hour from the West coast, half that from the East and 4 or 5 from the South. We could make up a bed for you, provided you don't mind the absolute fucking mayhem my two kids cause.
Oh, and our youngest cat is about to give birth in a couple of weeks so we'll be snowed under with kittens, too. More mayhem. :D
rokket posted Sun, 21 July 2013 at 4:47 PM
Anyhow, I am getting closer to achieving my goal.
This was done by dupicating Ryan and using the dupe to create the glow. Edge blend with displacement. I used the normal diffuse and specular channel instead of the ambient.
I am getting there.
