Subject: What am i missing?
Sheedee opened this issue on Jul 20, 2013 · 9 posts
Sheedee posted Sat, 20 July 2013 at 10:10 AM
Howdy folks;
Just installed Freak 5 for Poser...
when loaded...get a pop up saying that things are missing...
DSON importer?...where can i get it?...how do i install it?...
thanks for viewing...
PoserPro 2014
ironsoul posted Sat, 20 July 2013 at 11:15 AM
Search on the Daz site for DSON.
hborre posted Sat, 20 July 2013 at 11:53 AM Online Now!
Don't be deceived, none of the Genesis characters work well in Poser unless you use the DSON Importer.  And even then, there are still many unresolved issues which may never be corrected.  Search the forum for related threads and posts.
JoePublic posted Sat, 20 July 2013 at 12:02 PM
You first have to install the DSON importer into Poser's main directory:
http://www.daz3d.com/dson-importer-for-poser
Then the DSON companion files go into an additional "Genesis" runtime you have to link to Poser.
Then you can load Genesis figures into Poser.
BUT...Some things like the scaling are completely broken and the bends are also inferior compared to using Genesis in Studio.
icprncss2 posted Sat, 20 July 2013 at 4:53 PM
If you do not have at least DS4 installed on your system, you much make sure the install DS4.x files is checked when you install the DSON importer.
This gives the module the DS4 files it needss to "translate" it into Poser speak.
If you have a version of DS4 installed, it doesn't matter.  Also make sure the DSON importer is installing to the Python folder inside the Runtime folder which is in the main Poser app folder.  This is where it looks for it by default.
Some users get decent results using DSOn and others get crappy results.  I've always ended up with crappy results so I won't say mucy more....
Sheedee posted Sat, 20 July 2013 at 5:17 PM
Well bottom line:
It seems that after reading these posts about Freak 5 in Poser...there seems to be more negative reactions then positive...
I think that if i want to use Freak 5 to its full potential, and without glitches and errors...i might as well just install him into Studio, where it gives no problems and works the way he is supposed to work...after all he was designed for Daz anyway. The problem is that mostly i use Poser for my work instead of Daz Studio...so that is why i am a bit dissapointed to read that it will never work perfectly within Poser...
So at the end of the day...if i want to use any Genesis base figure...i will just use Studio.
Funny thing is...that no where the vendors and the creators of the Genesis platform figures make known all the issues that i read here in the posts...yes...they created the DSON importer to make it all work in Poser...but then why all the glitches and imperfections?...they never mention that you will be confronted with them...in my opinion they could at least have said that we must not expect any Genesis figure or its derivatives to work as good in Poser as it works in Studio. At least that way you would know before hand what to expect.
SamTherapy posted Sat, 20 July 2013 at 5:23 PM
Welllll...
That'd be like listing everything you don't get included when you buy a TV, for example.  I don't think DAZ ever claimed you'd have error free, fully functional Genesis features in Poser, same as your TV box doesn't say "Elephant not included".  :)
As you said, the simple solution is to use Studio, which is what the Genesis figures were designed for.  AFAIK, the DSON stuff is to give you some functionality in an app that isn't immediately compatible with the Gen figures.
TrekkieGrrrl posted Sat, 20 July 2013 at 6:07 PM
Well... Sam.. Although I agree with some of what you say, it would be like selling an NTSC tv in Europe. Or a PAL TV in the US. Sure you get a TV, but hey.. you can't use it.. too bad...
SamTherapy posted Sat, 20 July 2013 at 6:18 PM
Not quite.  TVs - Here in the UK - say what system they use on the box.
