ghostship2 opened this issue on Jul 22, 2013 · 8 posts
ghostship2 posted Mon, 22 July 2013 at 1:51 AM
ironsoul posted Mon, 22 July 2013 at 2:57 AM
The softness value is high, is that what you intended?
ashley9803 posted Mon, 22 July 2013 at 3:19 AM
Are you after a simple red glossy/shiny reflect or a radiosity effect, where the red is reflecting light diffusely onto other objects? The former should be easy with a red specular value, the latter requires IDL rendering. Are the valves a separate material zone to the rest of the suit?
millighost posted Mon, 22 July 2013 at 8:17 AM
You could simply multiply the reflection with an image texture map (see illustration).
hborre posted Mon, 22 July 2013 at 8:42 AM
Background on the reflect node should be black unless you are intend to plug an image into it.
SamTherapy posted Mon, 22 July 2013 at 11:51 AM
BTW, the valves shouldn't all be red. Some of 'em are blue on the real thing.
bagginsbill posted Mon, 22 July 2013 at 1:22 PM
ghostship2 posted Mon, 22 July 2013 at 9:11 PM
