Subject: Re-apply Skin MAT - EZSkin undo?
Gator762 opened this issue on Jul 24, 2013 ยท 4 posts
Gator762 posted Wed, 24 July 2013 at 12:23 PM
My computer is in the middle of a long render, and all the nodes for skin materials are a bit daunting anyways.
To undo changes made with EZskin2, can I simply re-apply the character's MAT?
JoePublic posted Wed, 24 July 2013 at 12:43 PM
Yes and no. EZSkin uses the alternate diffuse node while simpler texture sets are usually plugged into the main diffuse node.
Which EZSkin disables by setting it to black and to 0%.
So reapply the original MAT file and if the skin renders black, use Scenefixer to set the diffuse channel to white and 100% again.
Gator762 posted Wed, 24 July 2013 at 1:19 PM
Awesome, thanks, I would have never had found that!
ashley9803 posted Thu, 25 July 2013 at 4:08 AM
If you re-apply a texture over EZskin that doesn't have SSS then the black-skin issue doesn't occur.
From that point on you can re-apply EZSkin over any other skin map.
