Subject: Fitting Room plus Custom Textures
TerriJohns opened this issue on Aug 09, 2013 ยท 3 posts
TerriJohns posted Fri, 09 August 2013 at 4:01 PM
Another noob question from yours truly.
I took a pair of dress shorts from an older Poser model and was able to get it to fit decently to Roxie using the new Fitting Room. Then I saved the newly fitted dress shorts as a figure for later use.
If I want to create a texture map for these newly created shorts, am I safe using the original template for the old dress shorts, or is there a better way when dealing with clothing items post-fitting room?
vilters posted Fri, 09 August 2013 at 5:27 PM
The fitting room maintains the uvmapping.
So, YES, you can use the original template.
TerriJohns posted Sat, 10 August 2013 at 2:03 PM
Excellent, thanks!
