Subject: What is a p2z file?
moushie opened this issue on Aug 09, 2013 · 6 posts
moushie posted Fri, 09 August 2013 at 4:58 PM
Pardon my ignorance, but I'm only familiar with pz2 files. So what's a p2z, and can I use it in Poser 4?
Medzinatar posted Fri, 09 August 2013 at 5:09 PM
it's a pose file that has been compressed with gzip.
I don't recall if P4 can read them (it's been 10 years since I have used that version)
The modern versions of Poser have a utility to decompress.
You can manually extract file and give it extension of pz2
TrekkieGrrrl posted Fri, 09 August 2013 at 6:27 PM
PoserPro (the original Poser 4 Pro that is) and onwards reads them. Not sure about Vanilla Poser 4.
No need to decompress unless you want to poke around inside the file. Poser reads them just fine :)
moushie posted Fri, 09 August 2013 at 6:30 PM
Answers my question perfectly. I'll unzip, rename, install piecemeal. Many thanks indeed.
PhilC posted Sat, 10 August 2013 at 3:49 AM
Poser has a utility that will batch uncompress them for you. Go to Scripts > Utility > uncompressPoserFiles.
moushie posted Sat, 10 August 2013 at 10:34 AM
Thanks, Phil. Noted.
