ockham opened this issue on Aug 12, 2013 · 6 posts
ockham posted Mon, 12 August 2013 at 3:20 PM
I've probably asked this several times before, because this courseware project has been in the pipeline for 2 years while I've been twiddling my damn thumbs.
FINALLY the publisher has settled on a "shell", so I FINALLY know the desired connections.
By now HTML5 looks like the best choice for my animation and graphics modules, and by now HTML5 seems to have settled down and picked up a good variety of tools, much more than it had 2 years ago.
So the question is: Any recommendations for HTML5 development helpers? Specifically helpers with the Canvas stuff as basis for images, lines, animations, etc.
timarender posted Mon, 12 August 2013 at 4:05 PM
Adobe offer trials of "Dreamweaver CS6". Whilst still allowing the user to get their hands dirty with 'code', it probably includes a number of functions to do neat HTML5/Canvas tricks. I might also guess it loves using files from other Abobe products.
(I would be interested in what Ockham might find. Whilst not being obviously related to Poser; it would be pleasing to see what tools might help allow a Poser user to generate simple HTML5 versions of their Poser animations.)
uli_k posted Mon, 12 August 2013 at 9:51 PM
I like MotionArtist (I'm biased of course). It allows you to host Poser scenes to take snapshots.
R_Hatch posted Tue, 13 August 2013 at 12:04 AM
I've been trialing WYSIWYG Web Builder, and I'm liking it a lot. Very intuitive interface.
ockham posted Tue, 13 August 2013 at 4:13 AM
Thanks, I'll look at all of those!
ockham posted Fri, 16 August 2013 at 7:11 PM
Update: After trying those tools and looking around, I think I've found the right path.
I'm starting with a whole bunch of code that involves text and images and vector lines, which I wrote up in a private 'language' for a Windows-based courseware engine that I also wrote. The whole bunch of code needs to be converted into HTML5 so it can be run by platform-independent commercial courseware engines like Moodle.
A few lines of my code:
ITEM LABEL TERMSULC
LOC 89 210
BLINK
LINECOLOR 3
LINEWIDTH 5
SHAPE -43 25 L
SHAPE -12 18 L
SHAPE 15 9 L
SHAPE 34 30 L
SHAPE 101 189 M
@Terminal sulcus
ITEM LABEL FORCEC
LOC 114 190
BLINK
LINECOLOR 7
LINEWIDTH 7
SHAPE -3 19 L
SHAPE 93 205 M
@Foramen cecum
HTML5 has two different graphics systems: Canvas and SVG. After a quick look, it's obvious that SVG is what I need. It has all the same vector commands in a different format.
Randomly picked piece of SVG:
<g
transform="translate(600,150)"
id="SecondHand">
<g
id="RotSecondHand">
<path
d="M 0,-82.5 L -2.5,-75 L -4.71875,-8.8125 C -7.85655,-7.12467 -10,-3.81029 -10,0 C -10,3.9979 -7.64307,7.43129 -4.25,9.03125 L -2.5,30 L 2.5,30 L 4.25,9.03125 C 7.64307,7.43129 10,3.9979 10,0 C 10,-3.81029 7.85655,-7.12467 4.71875,-8.8125 L 2.5,-75 L 0,-82.5 z M 0,-2.5 C 1.38,-2.5 2.5,-1.38 2.5,0 C 2.5,1.38 1.38,2.5 0,2.5 C -1.38,2.5 -2.5,1.38 -2.5,0 C -2.5,-1.38 -1.38,-2.5 0,-2.5 z "
style="opacity:1;fill:#800000;stroke:black"
id="SecondHandPath" />
Same underlying commands, different format.
After choosing SVG, I looked around and found Inkscape, which is pretty clearly the best free tool for building SVG from scratch or from existing images and lines.
http://inkscape.org/
I may use Inkscape directly for the whole conversion, or I may use it for some trial conversions until I understand the 'mapping', and then write a mass converter in Python. Most likely the latter.
Thanks again for the suggestions! They helped to guide me in the right direction.
