LuxXeon opened this issue on Aug 15, 2013 · 7 posts
LuxXeon posted Thu, 15 August 2013 at 8:27 AM
Attached Link: Free Saturn Chair Download (.OBJ version)
Hi, everyone. I would just like to introduce my latest freebie:This is a model of the modern Saturn Chair; a contemporary, elegant design which comes in several variations, of which this is my personal favorite. This model can easily provide a modern look and feel to your arch/viz interior renders, or it could also work very nicely as a character prop.
The .OBJ version of the chair is available now in Freestuff** here**, and the .MAX version is available for download here. It comes complete with COLOR and BUMP texture maps for the SEAT portion, including 3 different leather color styles to choose from, so it will be easy to match this chair with almost any interior decor! You could also apply just about any procedural or tileable material, and it should map nicely. The metal base portion is also UV mapped, but doesn't require any color or bump textures; any basic raytraced metal or plastic shader will work nicely for that. The topology is all "quads", with a detailed, but optimized poly count of just 25,898, and 25,868 verts. The geometry is well suited for medium to very close up renders, and has been tested to render cleanly, even with unbiased, path-tracing render engines.
You could also download the object in both .MAX or .OBJ formats in the following locations, and view the wireframes of the model:
The POSER-specific OBJ version was exported with a scale conversion that should load with the appropriate scaling into Poser 9 and above. To ensure proper import into Poser, BE SURE to DE-select all check box options boxes in the Import Options dialogue. DESELECT the "Centered", "Place on Floor", "Percent of Standard Figure Size", etc. options in the import dialogue box after you select the poser .obj file, and then the object should load with correct scale into the scene. In DAZ|STUDIO, simply choose the Poser-scaled .obj version, and import with Poser Preset option from the import dialogue box. BLENDER users, obviously, choose the Blender scaled .obj. All other software applications may be best suited to import the standard .obj file.
Enjoy, and let me know if you have any problems or need any assistance in using the object in your work. Thanks.
______________________________________
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
LaurieA posted Thu, 15 August 2013 at 9:47 AM
WOW! That's cool :D. Thanks so much!
Alisa posted Thu, 15 August 2013 at 10:26 AM
Nice! Thank you :)
Cheers,
Alisa
RETIRED HiveWire 3D QAV Director
bagginsbill posted Thu, 15 August 2013 at 10:31 AM
FaeMoon posted Thu, 15 August 2013 at 5:04 PM
Excellent Chair!! Thank you!
boudicca36 posted Thu, 15 August 2013 at 9:40 PM
Yes Thank You! :-)
luckybears posted Wed, 21 August 2013 at 5:12 PM
NICE MODELLING, TY
