luckybears opened this issue on Aug 21, 2013 · 5 posts
luckybears posted Wed, 21 August 2013 at 4:53 PM
Thinking of a new comp to get the most out of PP2014. If I get a new desktop with an i7 processor will Poser render using 7 threads?
JimTS posted Wed, 21 August 2013 at 5:12 PM
The 6 cores will render 11 and leave resources for your web browser
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
ghostship2 posted Wed, 21 August 2013 at 9:26 PM
matters what i7 you get...most have 4 cores, 8 threads. high end ones have more cores and more threads...loook up the specs of the Intel processors and such to get better info. usually intel based CPU's have x number of cores and use Hyperthreading to run an extra thread off each core. I dont think the extra threads are as fast as the main thread but someone else with more knoledge will chime in about it.
aRtBee posted Thu, 22 August 2013 at 3:06 AM
i7 4 cores will run 8 threads, my i7 990X is 6 cores and runs 12 threads (though Vue is limited to 8 threads max). Overclocking helps. All threads are equally fast, speed is temperature-driven (higher temp=lower speed). TMonitor (freebie on the net) can tell how speedy your individual threads are at runtime. Speccy (freebie on the net too) can tell you about the temp of the individual cores.
Why run 7 or 11 threads? Just manage your priority settings. This is how: http://www.book.artbeeweb.nl/?p=162
have fun
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
luckybears posted Sat, 24 August 2013 at 2:28 PM
Thank you :)
