jackhalsey opened this issue on Aug 25, 2013 · 5 posts
jackhalsey posted Sun, 25 August 2013 at 5:18 PM
I got a new computer running windows Ultimate 7 with 8 cores and 16 gigs memory. It has a AMD Radeon HD 7700 card.
I installed Poser 2012 and then Maya 2012. I created a pz3 scene in Poser and saved it. Then went over to Maya 2012 and tried to import it.
It said "error reading file." I checked the plug in manager and the poser fusion plugin was loaded. I tried creating another pz3 scene and the same response.
The whole setup worked before in the other computer. Any ideas how to fix this.
Thank you.
markschum posted Sun, 25 August 2013 at 7:32 PM
are you using file compression or extenal binary morphs ?
jackhalsey posted Sun, 25 August 2013 at 7:54 PM
I assume file compression which is that I used before as I create the scene and then click on save as then give it a name and it is saved as a pz3 file. Its the same procedure that used to work.
Teyon posted Sun, 25 August 2013 at 8:14 PM
Try installing Maya and then Poser along with Poser Fusion and see if that works. Otherwise, contact support.
jackhalsey posted Mon, 26 August 2013 at 2:20 PM
Finally got it solved thanks everybody.
