dean fleet opened this issue on Sep 03, 2013 · 7 posts
dean fleet posted Tue, 03 September 2013 at 6:24 AM
Does any body have ideas on this. I have been using Bryce 7.1 for a long time and suddenly just after a sucessful rendering and save to disc i get the warning above. I can still render to disc but no more render then saves. It is a real pain.
Thanks for any ideas. I have tried a reinstall.
Navim posted Tue, 03 September 2013 at 7:15 AM
That has happened to me also. Don't have a clue and will leave it to the tech people at Daz.
bobbystahr posted Tue, 03 September 2013 at 10:56 AM
File a bug report at DAZ would be my recommendation...I've not run into this myself....
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
dan whiteside posted Tue, 03 September 2013 at 7:57 PM
That's very strange because a .dll is a MS link library extension. Bryce plugs use mostly .BRIO or .BREO extensions. Sounds like something missing outside of Bryce (not that helps you much!)
peedy posted Tue, 03 September 2013 at 11:47 PM
If/when I have that (Never had it in Bryce), I go here:
Download and install the file.
That usually works for me.
Corrie
Navim posted Wed, 04 September 2013 at 8:05 AM
I am curious if this is a win 8 problem? What platform are you on Dean? I am running 8.
chohole posted Wed, 04 September 2013 at 11:01 AM
Have you done any software updating or let anything update anything on your PC. SOmetimes there have been problems with missing .dll files, but usually this has been with visualC+ DLLs which are missing in a 64 bit windows install.
THere are redistributals availalbe at MS to sort this out.
The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
