dolittle opened this issue on Sep 25, 2013 · 5 posts
dolittle posted Wed, 25 September 2013 at 11:47 PM
Hi,
I'm having trouble with Bryce 7.1.0.109 Pro. When I try to render 48-bit files using "render to file" I am periodically getting corrupted renders, and -- less often -- crashes. This happens whether I export to tiff, png, etc. Doesn't seem to happen with 24-bit files, though I haven't used 7.1 much. I'm using windows 7 ultimate, 64 bit.
Haven't had any trouble with render to file in the past, however, I seem to remember reading that it was somewhat problematic.
Anybody else have this happen? Any solutions?
Cheers,
Doittle
Navim posted Thu, 26 September 2013 at 10:57 AM
I have the same problem. Don't have a fix for it though.
Mike
bobbystahr posted Thu, 26 September 2013 at 9:20 PM
Post a pointless bug report you 2...it might get some attention
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
Navim posted Tue, 01 October 2013 at 7:32 PM
I just rendered an 8.8X11 @ 300ppi with no trouble. Have another image that will go bigger but I am waiting for Daz to fix the noggins rabbit files as I need a little white fuzzy bunny to finish it.
EricofSD posted Sat, 12 October 2013 at 7:59 PM
It might help to know what system you have. Assuming you have more than 8 native cores (AMD 8 core or Intel 16 core - 8 native, 8 virtual), then set your render priority to maximum.
I also assume you have win 7 with 16g ram and hopefully an SSD drive.
That's about the max that B7 can handle.
