Forum: Freestuff
Subject: Halloween Kitty Candle Centerpiece
LuxXeon opened this issue on Oct 17, 2013 ยท 7 posts
LuxXeon posted Thu, 17 October 2013 at 1:52 PM
Attached Link: Kitty Candle Centerpiece (OBJ Version)
You might imagine this unique model as a Halloween centerpiece, useful for specific arch/viz interior decor; gracing a fireplace mantle, for example, or as a fun prop for any character render.
Modeled entirely in 3dsmax, this highly detailed, unique candle holder model is available as a native 3dsmax 2012 scene file (.max), and also in several scaled .obj formats, for importing easily into other applications, like Blender, Poser, or Daz|Studio. This object comes complete with high detail texture maps for every necessary material channel, for the most control over your resulting render. There is a custom diffuse (color), bump, and specular map for each sub-object, and also an illumination control map for the optional flame model*, if you wish to use it. The model consists of 17,915 polygons and 18,325 verts. Each texture map is provided in maximum quality JPG format, with resolution of 2048x2048 pixels, and is suitable for extremely close-up rendering. You may need to tweak or adjust the power of the bump and specular maps in your software to get the optimum results for rendering.
*I have included a fairly simple flame object, which you can load with the model in youre scenes. If your software supports self-illumination, I have provided a self-illumination map to use, if desired. The preview renders I created for this object in Octane are using the flame, illuminated with the same map I have provided. I recommend using it only if you need the candle lit, and have no volumetric flame/fire alternative in your software. Otherwise, using particles and volumetric materials to simulate a flame is probably a much better solution.
Click Here to download the .OBJ version from Freestuff (the .Max version is waiting approval).
Optionally, you can also download this model from the following resource locations:
Turbosquid.com
ShareCG.com
As always, enjoy the model, and please contact me if you have any questions about how to integrate this model into your renders. Please refer to the README included in the download for specific instructions on how to import this model into your 3D application of choice.
______________________________________
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
