Forum: Bryce
Subject: Bryce query
Anthony Appleyard opened this issue on Oct 27, 2013 · 12 posts
Anthony Appleyard posted Sun, 27 October 2013 at 5:50 PM
I have just bought (legitimately) Bryce 7 Pro. The 2 files of it that I successfully downloaded are:-
BryceLightning_7.1.0.109_Win.exe , 11,116 Kbytes
BryceProContent_7.0.0.19_Win.exe, 17,639 Kbytes.
Are these a complete Bryce 7 Pro setup?
Where are its manual and readme?
How do I install them?
StuartB posted Mon, 28 October 2013 at 9:16 AM
They are just add ons which you install after installing Bryce. You just click or double click on them to install. If you don't have a download link for Bryce 7 you should contact Daz here: http://www.daz3d.com
You could also join the Daz Bryce forums while you are there, there's loads of help there.
jennblake posted Mon, 28 October 2013 at 9:48 AM
Hi.
When I downloaded my files from Daz for Bryce 7 Pro I had the following files:
Bryce_(num)Win32
Bryce Content Win
Bryce Lightning
Bryce Pro Content
So it seems you may be missing some files for installation.
Hope this helps.
Anthony Appleyard posted Mon, 28 October 2013 at 11:22 AM
Thanks. I have downloaded 2 more files, and I now have:-
Bryce_7.1.0.109_Win32.exe , 259.850 Mbytes
BryceContent_7.0.0.21_Win.exe , 686.116 Mbytes
BryceLightning_7.1.0.109_Win.exe , 11.116 Mbytes
BryceProContent_7.0.0.19_Win.exe , 17.639 Mbytes
The two long files add up to nearly a gigabyte, and they took an age and an age to download.
jennblake posted Mon, 28 October 2013 at 11:29 AM
Sounds like it should now be correct. :) Good luck!
Anthony Appleyard posted Mon, 28 October 2013 at 11:32 AM
Should I install from all four of these files?
Where can I get a Bryce 7 manual?
jennblake posted Mon, 28 October 2013 at 11:44 AM
Yes you should install all 4 file.
After you have installed the program you will find an Artist's Guide or manual for the program under Start/All Programs/DAZ 3D/Bryce 7
Also if you go to youtube and type in Bryce tutorials you will find a wealth of knowledge to go through. :)
dyret posted Tue, 29 October 2013 at 1:09 AM
Bryce Lightning isnt needed if you are only going to use Bryce on one machine. It makes Bryce able to render on several computers for faster renders.
Sacha45 posted Wed, 27 November 2013 at 12:53 AM
Your idea is outstanding the issue is one thing that not enough persons are speaking intelligently about. I am very completely satisfied that.
Sacha45 posted Fri, 31 January 2014 at 3:48 AM
Quote - Your idea is outstanding the issue is one thing that not enough persons are speaking intelligently about. I am very completely satisfied that.
plagiarism-checker.info
Sacha45 posted Wed, 01 October 2014 at 5:25 AM
Quote - > Quote - Your idea is outstanding the issue is one thing that not enough persons are speaking intelligently about. I am very completely satisfied that.
__________________________
http://definitions.uslegal.com/p/plagiarism/]http://definitions.uslegal.com/p/plagiarism
http://en.wikipedia.org/wiki/Plagiarism]http://en.wikipedia.org/wiki/Plagiarism
IO4 posted Sat, 08 November 2014 at 7:06 AM
The B7 guide is available here; http://docs.daz3d.com/doku.php/artzone/pub/software/bryce/start
Beginners tutorials for Bryce
Bryce Arena
