Subject: So I've tried everything I can but I'm back with the same problem...Can someone
LarryWheeler opened this issue on Oct 30, 2013 · 4 posts
LarryWheeler posted Wed, 30 October 2013 at 6:39 PM
I have downloaded Victoria 4.2 and Victoria++ morphs but I can't seem to get the morphs to load correctly. After I click to load the dials appear but there is no response. Like the pregnant morph will load into the parameters tab but when I move the dial nothing happens. The shoulders move a little but that's it. I even go to my V4 folder and run the initalization but when I go back and load V4 none of her morphs work. It's like her body is still locked or something. Everything I do doesn't seem to work. If anyone can help I would apprecieate it. Thanks.
hborre posted Wed, 30 October 2013 at 6:58 PM
Okay, I believe that we may have asked before, where is Poser installed and which OS are you currently using?  Are the morphs installed into the same runtime as Victoria 4.2?
LarryWheeler posted Wed, 30 October 2013 at 7:04 PM
Ok I am using a Mac OS X version 10.7. Poser is in my applications program. Victoria 4.2 is in a seperate runtime as V4 ++ and the morphs
hborre posted Wed, 30 October 2013 at 9:44 PM
I am not familiar with the MAC environment but I assume the procedures are relatively the same under a Windows OS.  When installing V4, there is an primary initialization to prep the model for morph channels.  Then install the Morph++ pack and rerun the initialization again to prep the model to receive the pack.  Load a new V4 into the scene and inject the morphs++.  Everytime a new morph pack is introduced, the initialization must be rerun.  To check if the initialization had taken, load a base V4 into the scene and look at the Parameters tab for a new channel entitled Morph++.  Everything should work after injecting the pack.  Do not attempt to add morphs to a V4 model already saved into your Library or .pz2 scene prior to installing the Morph++ pack, those models would not have the appropriate channels established to accept the pack.
