piccolo_909 opened this issue on Nov 01, 2013 · 4 posts
piccolo_909 posted Fri, 01 November 2013 at 2:46 AM
I ran into a weird problem thats occuring on one of my files. When i click the rendering button, one of my textures says "Can't load texture: Bad File" and i found out that it was my HDR file attached to my Diffuse IBL. The thing is, i haven't had a problem with this HDR file before. This happens after rendering the scene about 3 times (doing test renders), and the only way i can fix it is by closing poser and re-opening it. Does anyone know what this error is and why it happens?
I'm using Poser Pro 2012 SR3.1
I was thinking it's a memory issue since im on 32 bit system, but my scene only has 2 characters and several props. And when i check the tash manager, i don't see poser going past 1 gig, so i'm at a loss at what's causing that error.
MistyLaraCarrara posted Fri, 01 November 2013 at 11:41 AM
use to see that message after a render, poser didn't have memory to reload the textures. reboot used to cure it.
the python menu had a scene inventory script. gives an idea of much is loading into a scene.
luckybears posted Fri, 01 November 2013 at 5:46 PM
Have you: renamed the file: moved it or deleted it
Thatr is the usalyy occuraaance for this message.
piccolo_909 posted Sun, 03 November 2013 at 2:08 AM
MistyLauraPrincess: Yeah, i checked the task manager though, and poser was only using 900 mb of memory, which is well below the limits. And if it was a memory issue, wouldn't it fail on the first try?
luckybears: Nope, nothing was done to the file.
