Subject: Not loading ogjects
redtiger7 opened this issue on Nov 25, 2013 · 6 posts
redtiger7 posted Mon, 25 November 2013 at 1:57 PM
All my content is still sitting in the runtime of my old Poser 7 instalation. Even my favorites are copies of the shortcuts from the  P7 runtime. Whenever I try to load an object or previous work, PP14 can't find it, and looks in it's own library, not teh p7. I loaded the P7 runtime as a new library but it's showing up as empty. What am I doing wrong?
luckybears posted Mon, 25 November 2013 at 5:29 PM
'Objects', are you saying OBJs, lightwave or pp2s?
If PP2 then the Poser library gives you the option to associate the  P7 library. Look at that option f you have not removed the p7 lib. Add Library.
redtiger7 posted Mon, 25 November 2013 at 6:23 PM
It's all kinds of different files, geometies, deltas.... I've added the P7 library, but it only shows up as an empty folder.
How do I associate the P7 library?
EnglishBob posted Tue, 26 November 2013 at 4:38 AM
Quote - I loaded the P7 runtime as a new library but it's showing up as empty. What am I doing wrong?
I suspect this may be where the problem lies - it seems that Poser isn't seeing your P7 runtime. When adding a runtime, you should actually select the folder that contains the runtime, not the runtime itself. In your case, that would be the Poser 7 folder.
redtiger7 posted Tue, 26 November 2013 at 11:28 AM
That worked! Thank you very much.
EnglishBob posted Tue, 26 November 2013 at 11:37 AM
You're welcome! :-)
