Subject: How can I make parts of clothes invisible or remove them?
XoechZ opened this issue on Dec 01, 2013 · 7 posts
XoechZ posted Sun, 01 December 2013 at 7:03 AM
Hello!
I have just started working with Poser 10 after a long time using DAZ Studio and there is one thing where I need a little help:
How can I make parts of clothes (or shoes, hair, or whatever) invisible or remove them completely when I dont want them?
In DAZ Studio I opened the surfaces tab, looked for the material zone and turned its opiacity to 0%. Then it was gone, in preview and in the render.
In Poser 10 I tried the same in the material room and set the transparency to 100%. But that does not work. It becomes transparent, but the outlines are still visible, which makes it a bit look like glass.
So, how is that done correctly in Poser 10?
Thanks in advance!
MistyLaraCarrara posted Sun, 01 December 2013 at 7:47 AM
you'd need to set specular to 0, remove reflect if there is any, etc.  😄
XoechZ posted Sun, 01 December 2013 at 7:58 AM
Really? Ok, then it is more work than I am used to :-)
Thanks for the answer!
MistyLaraCarrara posted Sun, 01 December 2013 at 8:11 AM
you could save it to the material library as a transparency preset,
then it'll be one click from now on.
hborre posted Sun, 01 December 2013 at 8:13 AM Online Now!
There are multiple ways to make parts invisible.  The quickest way is through the Hierarchy Editor found through the Windows part of the taskbar above or the Parameter/Properties Panel.  This is illustrated above.  Clicking on the eye in the Hierarchy Editor controls invisibility. The 3rd method, which is more involved, is create a black & white transparency mask to hide the unwanted parts.
XoechZ posted Sun, 01 December 2013 at 9:37 AM
Thanks for your suggestions!
I will try all methods and see which one is the best for me.
ypvs posted Tue, 03 December 2013 at 6:38 AM
As above - set diffuse/highlight/ambient/reflection to solid black 0,0,0 from the color picker. Transparency AND Edge to 100% with no map. Save to material library for later use.
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Intel Q9550 Quad Core cpu,  16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
