Forum: DAZ|Studio
Subject: G2 character textures
cedarwolf opened this issue on Dec 06, 2013 · 4 posts
cedarwolf posted Fri, 06 December 2013 at 2:52 PM
I know that the Genesis characters will take V4 textures, but I can't seem to get that to work with Genesis 2.  Any suggestions?  Also, any links for free G2 textures?  I haven't found any yet myself.
gloomy007 posted Fri, 06 December 2013 at 3:12 PM
From what I understand you need  Victoria 4 for Genesis 2 to use V4 UVmapping on G2.
The shape is availible in DAZ store : http://www.daz3d.com/victoria-4-for-genesis-2-female
Just like with Genesis needs Generation 3 Iconinc shapes to use their textures.
DAZ Studio Coordinator.
You can contact me in english.
Jij kan mij berichtje sturen in Nederlands,
Mozesz sie ze mna skontaktowac po Polsku
Medzinatar posted Fri, 06 December 2013 at 5:20 PM
In addition to getting the V4 UV set, you will have to update the material files.
PZ2 doesn't work on Genesis 2, they have to be converted to DUF.
If you don't want to buy a conversion utility, they are fairly easy to convert.
Just apply the texture to a V4 figure, then use the "Add Asset" button to save as a material preset.  you will then have a DUF that works on G2F.
If you have the UV sets, you can also convert textures with the Map Transfer utilty.
For G2F, you can convert from v4,v5 or v6
RHaseltine posted Sat, 07 December 2013 at 9:13 AM
Quote - Just like with Genesis needs Generation 3 Iconinc shapes to use their textures.
Unfortunately not - because the layout of the material zones is different there is no way to get Gen 3 maps on later figures with a simple UV set swap - the maps need to be converted with Texture Converter 2 or the like. The Gen 3 shapes add a morph and an AutoFit clone for converting clothes.
