Subject: CR2 question show/hide Properties
grichter opened this issue on Dec 08, 2013 · 6 posts
grichter posted Sun, 08 December 2013 at 4:16 PM
Did a forum search on show properties and reveal properties and the probelm is the search is too broad and we use the would properties way to much. After digging thru pages and pages of posts.....here I am.
Have a figure (Purchased item-CR2) where when you look at the body actors the properties pallet is blank. Granted I can do what I want and show and hide various body actors using the Heirarchy window.
But how do you turn that on and off?
TIA
Gary
Gary
"Those who lose themselves in a passion lose less than those who lose their passion"
PhilC posted Sun, 08 December 2013 at 4:33 PM
In later versions of Poser you can click the little arrow top right in the parameters panel and select the option to show the hidden parameters.
If you need to be more selective you will need to edit the CR2 file manually.
grichter posted Sun, 08 December 2013 at 4:41 PM
Quote - In later versions of Poser you can click the little arrow top right in the parameters panel and select the option to show the hidden parameters.
Know that for parameters. It's the Properties tab or pallet that is blank.
Gary
PhilC posted Sun, 08 December 2013 at 4:54 PM
ahhhh ok
I'm not able to duplicate that here. What figure is this? Is there any more information you can give us?
grichter posted Sun, 08 December 2013 at 5:04 PM
Quote - ahhhh ok
Thanks Phil
It is a confernece room where the walls are body actors to the floor (body).
PP2014 (one service release behind) On my lap top overseas vs my main set up back home. There are issues with Poser on my laptop relative to drag and drop after Poser has run for a couple of days. Let me reboot the computer and see what happens.
Gary
Gary
grichter posted Sun, 08 December 2013 at 5:12 PM
Reboot solved the problem. Since you can hide parameters in the CR2 I asumed the properties could be hidden too, so I went digging. My laptop needs more Ram.
Gary
