LuxXeon opened this issue on Dec 16, 2013 · 6 posts
LuxXeon posted Mon, 16 December 2013 at 1:10 PM
Attached Link: Plastic Milk Crate (OBJ Verison)
Hey all. Hope everyone is doing well.Today, I have a simple, but very intricate model of a plastic milk crate, available in several scaled .obj formats (the native .max scene file is pending approval), for importing easily into other applications, like Blender, Poser, or Daz|Studio. This object is modeled to scale, using standard milk crate dimensions of 11" high, x 13" wide(sides). Since these crates are used differently by several customers, manufacturers and suppliers are said to make them accordingly, to fit the customers’ specifications, so dimensions and mould styles can vary greatly from crate to crate. The model has been UV Unwrapped, and comes complete with texture maps for the color/diffuse, material channels. I've provided 4 different color texture maps in maximum quality JPG format, with resolution of 2048x2048 pixels, which is suitable for close-up rendering. Notice that you may need to tweak, or adjust, the diffuse and specular intensity on the model after import, to ensure an optimum render result. Seamless procedural materials should work fine on this model as well, and actually encouraged.
I modeled this object with the minimal amount of polygons needed to achieve the desired shape, however, I did add additional supporting edges to the model in order to create beveled edges to catch the light, and reduce any potential for render artifacts across various 3D render platforms. This model is intended for high resolution rendering and visualization, and is not suited for real-time game engines, without some optimization. The object consists of 20,989 polygons in total, and 19,344 vertices. The model is 99.5% quad polygons, and 0.3% triangles. There are no polygons on this model that exceed 4 sides.
*All preview renders were made with the Octane render engine, using the exactly the same texture maps that are included with the model. Please review the special instructions in the README.TXT for proper OBJ import.
Click Here to download this object from Freestuff on Renderosity. Alternatively, you can also use the following resources to download both the .max scene file, and the .obj versions, or preview more renders, including wireframes.
As always, if you have any questions regarding the use of this object, please feel free to contact me at the email listed in the Readme.txt.
I'll update this thread once the .max version is available on Renderosity, but you can get it now at either of the other two resources listed above, or at my DA profile page. Thanks!
______________________________________
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
