Subject: Using Poser when upgrading from Win XP 32 to Win 7 64
ChrisV opened this issue on Dec 16, 2013 · 7 posts
ChrisV posted Mon, 16 December 2013 at 2:35 PM
Hi all
I've searched the forums but can't seem to find answers to the following.
I'm about to upgrade my old Win XP 32 bit dual core sustem using 4MB RAM to a Win 7 64 bit quad core system with 8 MB RAM.  I have 2 questions regarding Poser:
1.   Will my existing 32 bit Poser 9 program run better under W4W in Win 64, specifically regarding using greater RAM availability for rendering?  If so, in what ways?
2.   If I 'side upgrade to PoserPro 64, will I still be able to use my, now very extensive, 32 bit Poser libraries with PP 64?
Experts' replies eagerly awaited!
vitachick posted Mon, 16 December 2013 at 2:40 PM
I did the same. Upgraded one comp from WinXP to Win7 for the 64 bit only.. Renders are faster and some that use to crash do not on the Win7. I did not install it to C drive but created a new drive D for it. I put all purchsed runtime items on external drive.., not the internal hard drive. Hope this helps..
Win10  Poser 2014/Poser 11 Daz3D
vilters posted Mon, 16 December 2013 at 3:06 PM
Poser9 is 32 bit, so limited to 32 bit RAM limit.
All PoserPro versions are 64 bit, and not limited in RAM usage.
All your runtimes are usable is all Poser versions. 32 and 64 bit, all Operating systems and all Poser versions.
aRtBee posted Mon, 16 December 2013 at 3:09 PM
  1. likely. In a 32bit Windows P9 uses 2Gb user ram unless you've tweaked the windows settings themselves already. In a 64bit Windows the 32bit P9 can use up to 3Gb.
BTW: the 64bit PPro will be sort of unlimited in this.
  1. yes, the library files are the same for P9, PPro, Daz Studio, Carrara, Vue and everything.
BTW you might find some useful stuff in http://www.book.artbeeweb.nl/?p=162 where I discuss Poser from just a pice-of-software point of view. Mainly PPro / Win-64bit oriented.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
aeilkema posted Mon, 16 December 2013 at 5:52 PM
Don't worry, many of all took this brave step before you and we all lived :-) You will gain a lot if you decide to go Pro!
Food for thought.....
hornet3d posted Tue, 17 December 2013 at 6:37 AM
Quote - Don't worry, many of all took this brave step before you and we all lived :-) You will gain a lot if you decide to go Pro!
I'll second that.  I made the change a few years ago with Windows 7 and Poser Pro 2010 and it was a major step forward.  Now using Poser 2014 and doubt very much if I could step back to 32bit without major frustration.
ChrisV posted Tue, 17 December 2013 at 11:06 AM
Many thanks to all for your comments, particularly aRtBee who'se web pages I fine enlightening and insightful.
I'll be firing up the new PC this week to see how well P9 works on the new rig and I'll upgrade to Poser Pro in the New Year (when I'vew managed to extiguish my red hot credit card!)
Many thanks again
ChrisV
