Subject: errors in poser9
goofygrape opened this issue on Dec 23, 2013 · 11 posts
goofygrape posted Mon, 23 December 2013 at 2:35 PM
At the start up I get a bunch of error mesages,WX PYTHON API,WX_INIT_PY UVX APS.
What the heck is or are they any idea to fix will help.
thanks
ps there is a lot more but they look like giberish .
willyb53 posted Mon, 23 December 2013 at 2:40 PM
See http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2876311
and make sure you have the lastest SR from smith micro
Bill
People that know everything by definition can not learn anything
goofygrape posted Mon, 23 December 2013 at 10:00 PM
Willyb53
I donot have IE11,I blocked it when the library would not load,do these erroes have something to do with IE
THANKS
willyb53 posted Mon, 23 December 2013 at 10:33 PM
If you blocked it after the library would not load, it was probably already installed by the automatic update from microsoft.  Have you installed the latest SR.  That is supposed to fix P9.
Bill
goofygrape posted Thu, 26 December 2013 at 11:03 PM
YES I installed the up date also blocked IE11 before my library comes up as it is suposed to,it just the errors before poser starts that I want to fix if possable .
thanks for your time
rokket posted Fri, 27 December 2013 at 6:25 PM
I went back to IE 10 and all those problems went away....
goofygrape posted Fri, 27 December 2013 at 7:47 PM
Rokket how do you go back to IE 10 that still might be the problem ?
rokket posted Fri, 27 December 2013 at 7:53 PM
I went back into the control panel to programs and features, clicked on IE11 and uninstalled it. My pc reverted back to IE10. If that doesn't work, you can go on the microsoft website and find IE10 and install it from there. But uninstalling IE11 should revert back to IE10 if you had it installed prior to 11.
goofygrape posted Fri, 27 December 2013 at 8:03 PM
this is what comes up on starting poser9
Rokket
I went to controll panel ect no IE11 OR IE10 in the files there?
rokket posted Fri, 27 December 2013 at 8:08 PM
Click on View Updates. Sorry, I forgot to add that step in there. Once you do that you will see IE11. Click on it and click uninstall.
goofygrape posted Fri, 27 December 2013 at 8:28 PM
Found it now to restart the comp.
Traceback (most recent call last):
File "C:Program Files (x86)Smith MicroPoser 9RuntimePythonlibsite-packageswx-2.8-msw-ansiwx__init__.py", line 14, in
import version
ImportError: numpy.core.multiarray failed to import
File "C:Program Files (x86)Smith MicroPoser 9RuntimePythonPoserScriptsposerStartup.py", line 14
poser.ExecFile(mainButtonsPath)SL_path = os.path.join(runtimeRoot, "Runtime", "Python", "PoserScripts", "Netherworks", "Scripts Auto Launch",
SyntaxError: invalid syntax
import version
File "C:Program Files (x86)Smith MicroPoser 9RuntimePythonlibsite-packageswx-2.8-msw-ansiwx__init__.py", line 45, in
from wx._core import *
File "C:Program Files (x86)Smith MicroPoser 9RuntimePythonlibsite-packageswx-2.8-msw-ansiwx_core.py", line 4, in
import core
ImportError: DLL load failed: The specified module could not be found.
this is the errors I have been talking about ,
