Subject: Question on DSON Importer
gohanf22 opened this issue on Dec 28, 2013 · 17 posts
gohanf22 posted Sat, 28 December 2013 at 1:42 PM
Does anyone know if they will be making a new one for Poser 10 and Poser Pro 2014 or they not going to? Or is there a workaround with the current DSON?
WandW posted Sat, 28 December 2013 at 1:46 PM
DSON Importer works fine for me in Poser Pro 2014.  Did you download the current version from DAZ and install the Starter Essentials and its Poser Companion files?
gohanf22 posted Sat, 28 December 2013 at 1:50 PM
Well when I tried to install it or when I did install it, it gives me an error at program startup that says: An error occurred while importing addon DSON: ERROR: DLL load failed: %1 is not a valid Win32 application.
Any idea how to fix it?
hborre posted Sat, 28 December 2013 at 2:40 PM
Are you sure you are using the right version?  There is a 32-bit and 64-bit version.
gohanf22 posted Sun, 29 December 2013 at 6:10 PM
Last I checked I was using 64 bit Windows. And I downloaded the right one to install so I have no idea why its doing this.
WandW posted Sun, 29 December 2013 at 6:26 PM
Are you running Poser 10 or PP2014?  You need the 32-bit one for Poser 10.  If you are using PP2014, make sure you are actually running the 64-bit version of Poser; it installs both 32 and 64-bit by default....
gohanf22 posted Mon, 30 December 2013 at 12:25 PM
I'm using Poser 10 and I got it sort of working now. I installed the 32 bit version. It still giving me an error but the models are loading. Thanks everyone for the help
drifterlee posted Tue, 31 December 2013 at 6:59 PM
I am using Poser Pro 2014 and the latest download of DSON Importer. I bought the Mil Cat 2 and it will not load at all.
WandW posted Tue, 31 December 2013 at 9:04 PM
Did you install both the DSON Core and Poser CF files for the kitty?
PS. Happy New Year!  😄
drifterlee posted Wed, 01 January 2014 at 7:43 AM
Yes, I did.
WandW posted Wed, 01 January 2014 at 8:27 AM
Did you install Genesis 2 Starter essentials?  I don't have the Cat, so I'm just tossing out ideas at this point...
drifterlee posted Wed, 01 January 2014 at 8:38 AM
Would the Genesis 2 starter essentials apply to the Big Cat? I have Genesis installed so I must have installed it.
RHaseltine posted Wed, 01 January 2014 at 8:51 AM
Do you get an error message? Is the cat listed as loaded but simply not visible, or isn't there even a ghost listing? Are you sure you are loading the figure and not materials etc.?
WandW posted Wed, 01 January 2014 at 9:00 AM
I believe it's based on Genesis 2.  The Gen. 2 Starter Essentials downloads (DSON Core and Poser CF)  will be in your DAZ account's Product Library and/or DIM. As I said, I don't have it, so I'm just tossing out ideas...
RHaseltine posted Wed, 01 January 2014 at 9:09 AM
The Big Cat 2 is a stand-alone figure, with its own mesh and rigging.
drifterlee posted Wed, 01 January 2014 at 9:45 AM
I try to load the cat and it is like the ghost of a cat and the program immediately freezes. That's wht happens. Do you have the Big Cat 2? for Poser
RHaseltine posted Wed, 01 January 2014 at 2:51 PM
I do, but I still need to download the latest SRs for Poser, so I can't test yet.
