grichter opened this issue on Dec 30, 2013 · 14 posts
grichter posted Mon, 30 December 2013 at 10:41 AM
Odd request-Looking for good Albino Skin Texture for V4, that I can then add my own makeups to.
If I do a color math routine, I can get the skin to the shade I want. Problem is it tones the makeup colors whiter also and they look odd. My photoshop skills suck and if I try to modify the skin tone in PS it looks like crapola.
Or should I try to put the makeup back like you would a tatoo with a blender node I think is how it is done so it by passes the color math routine.
I have the makeup around the eyes as a series of self created overlays
Thanks in advance for any suggestions
Gary
Gary
"Those who lose themselves in a passion lose less than those who lose their passion"
lkiilerich posted Mon, 30 December 2013 at 10:55 AM
What about this one? http://www.renderosity.com/mod/bcs/index.php?ViewProduct=63439
grichter posted Mon, 30 December 2013 at 11:18 AM
Thanks. Searched on light skin and albino, not on the word white :)
Will grab it since it is on clearance :)
Might have a solution by saving off the makeup as a png and plugging it back into one of the math nodes I used to desaturate the skin tone to start with. But massively late for work and will have to mess around more later tonight when I get back home.
(Why does work always have to get in the way of my poser projects?)
Gary
hborre posted Mon, 30 December 2013 at 12:07 PM
Bagginsbill created an albino shader set using VSS quite some time ago. You could control the intensity of the albino tint. Unfortunately, it was never updated to incorporate SSS in the latest Poser iterations, but I do believe that it relied on faked SSS.
WandW posted Mon, 30 December 2013 at 1:25 PM
Quote - Thanks. Searched on light skin and albino, not on the word white :)
Odd that it's not $3.50 like the Clearance items are supposed to be...
"Oh - the manual says that? I have never read the manual - this must be why."grichter posted Mon, 30 December 2013 at 4:35 PM
Quote - Bagginsbill created an albino shader set using VSS quite some time ago. You could control the intensity of the albino tint. Unfortunately, it was never updated to incorporate SSS in the latest Poser iterations, but I do believe that it relied on faked SSS.
Thanks for the tip on BB's shader. Will try to hunt down when I get home tonight. The texture I modified was a store bought one and had SSS built in. Not quite as many wires running around in this shader as a typical BB shader, but close.
Gary
grichter posted Tue, 31 December 2013 at 7:57 AM
Quote - > Quote - Thanks. Searched on light skin and albino, not on the word white :)
The reason it is not 3.50, is becuase the vendor has pulled all their products and the item is no longer for sale.
Gary
lkiilerich posted Tue, 31 December 2013 at 10:44 AM
Oh sorry I didn't saw that
grichter posted Tue, 31 December 2013 at 11:02 AM
Quote - Oh sorry I didn't saw that
Neither did I when I first looked at yeasterday morning. When I went back to buy it last night is when I discovered it was no longer for sale and the vendor has 0 items for sale in their store. Just thought you or anybody else reading this thread should know why it is not part of the clearence promotion.
Through the magic of photoshop and a lot of experimentation I got the makeup to look decent enough for me after countless test renders and I am calling my project 95 percent done via my color math routine. I am a tweaker, so the other 5 percent that is missing I will tweak it till I ruin it. :scared:
Gary
Winterclaw posted Tue, 31 December 2013 at 12:28 PM
Use a blender mask for the makeup so it doesn't get toned procedurally.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
grichter posted Tue, 31 December 2013 at 1:39 PM
Quote - Use a blender mask for the makeup so it doesn't get toned procedurally.
That is sort of what I did. Peeled the eyeshadow off the original and use it as a mask. No expert in Photoshop, but feathering the edges of the mask took to long for me to figure out. Needed a hard edge at the edge of the eyelid and feathered across the top to kill the hard edge there.
Using transmapped brows and the lips I didn't touch.
Gary
WandW posted Tue, 31 December 2013 at 1:40 PM
There's Ivory over at DAZ, but I don't know if she's pale enough...
"Oh - the manual says that? I have never read the manual - this must be why."RawArt posted Tue, 31 December 2013 at 5:23 PM
Jaager posted Tue, 07 January 2014 at 7:47 PM
There is a free texture at sharecg - Jenna for V4 - that has an albino texture
