Mariny opened this issue on Jan 07, 2014 · 8 posts
Mariny posted Tue, 07 January 2014 at 4:15 AM
I have installed V 4.2 and the morph pack.. I see the paths are ok, but can't see V4.2 base in there??
I have used install manager to install V4 so it should be right??
See picture.. All the paths are ok, but don't find V 4.2 base??
Marina
Razor42 posted Tue, 07 January 2014 at 4:29 AM
If everything is set up correctly you should find it here. It may be under the Poser Format/My Daz 3D Library section as well as I installed it manually a long time ago.
Hope this helps :)
Mariny posted Tue, 07 January 2014 at 6:32 AM
BUT
I then go to "pose" and inj base and morphs..But it's just the base options in the parameter.. The morphs +++ don't apply to her??
I think it's frustrating to work with this program:-( To inj the morphs is the easiest thing I do in Poser.. After struggling sooo much with DS 4.6 I don't ever think I will use sooo many hours to get my new V4 work inside DS..
This is one of the reason that make a vendor don't make a character to work inside DS but just Poser i think:-(
RHaseltine posted Tue, 07 January 2014 at 8:52 AM
If you have V4 set up ad working for Poser then it would be simplest just to point DAZ Studio to the same external library and share the files - right-click on Poser Formats in the last screenshot, then select Add runtime Directory, and select the folder that contains the actual "Runtiem" folder as you do when adding a location to Poser.
EddyMI posted Tue, 07 January 2014 at 12:52 PM
Live Long and Prosper
RHaseltine posted Tue, 07 January 2014 at 2:56 PM
Power Loader is however a separate install, for V4 base (to add the script and support files) and for the morph sets (to add the thumbnail and friendly description - otherwise it has only the product code and no thumbnail image).
atpo posted Wed, 08 January 2014 at 12:24 AM
I find that daz also default folder which you install folder.
if you change that folder name ,then daz display "cannat find".
jestmart posted Wed, 08 January 2014 at 11:47 AM
Clearly the paths are not okay if you can't DS can't find things. Post a screen shot of your Content Directory Manager with the DAZ Studio and Poser formats expanded.
