TheFlaneur opened this issue on Jan 07, 2014 · 2 posts
TheFlaneur posted Tue, 07 January 2014 at 2:14 PM
In Poser, when I load a V4 figure and inject base morphs and then Morphs++, should the new parameters show up grouped as 'Morphs++' in the Parameters panel? They don't for me, they simply show up inside a generic 'Morph' group.
I wouldn't even have noticed this as a possible issue but when using a character exported as a TriAx Weight-Mapped Figure from DS 4.6 (using this method), I see the Morphs++ group in the parameters panel, and everything seems setup as expected.
One issue that I suspect is related to this is that when injecting morphs from 3rd party FBMs, there is no visible change (except some injections seem to affect the bust area). Face morphs, however, work fine.
I installed V4.2 and V4Morphs via the Zip Installer in Poser and everything shows up in the Library just fine...
Am I missing something?
WandW posted Tue, 07 January 2014 at 4:33 PM
Reinitialize V4 using the .bat files in Windows or the .command scripts in OS X found in the Runtime/Libraries/!DAZ folder. The DIM does not do this automatically.....
