jbearnolimits opened this issue on Jan 07, 2014 ยท 5 posts
jbearnolimits posted Tue, 07 January 2014 at 3:43 PM
I wanted to show off a sword I made by animating it in poser. I started the first frame with it in the case and then went to about frame 30 and made a keyframe. I changed the y translation to pull the sword up out of the case. Then I went and made a keyframe at about 60 and moved the sword forward and down.
What I got however was the sword moving down between the first 15 frames and then bobbing back up to where it should be by frame 30. What happened?
EnglishBob posted Wed, 08 January 2014 at 3:15 AM
You should probably try linear interpolation for that type of movement.
geep posted Wed, 08 January 2014 at 8:22 AM
Attached Link: Animation Tutorial
Try using the Graph window to see what is happening.
Note - This tutorial was done for Poser 4 but the Graph window functions are basically the same for Poser 6.
Cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
jbearnolimits posted Wed, 08 January 2014 at 4:29 PM
Thanks Dr Geep, I have looked at other tutorials of yours and they help a lot. I will have to take a look here too.
geep posted Wed, 08 January 2014 at 4:47 PM
cheers,
dr geep ... :o]
edited 10/5/2019
