goido opened this issue on Jan 24, 2014 · 6 posts
goido posted Fri, 24 January 2014 at 8:37 PM
Is Poser 8 compatible with Windows 7 Pro 64 bit? Thanks.
willyb53 posted Fri, 24 January 2014 at 9:08 PM
It should if you have the latest SR. Note that some have had problems if IE11 has been installed.
Latest SR at http://poser.smithmicro.com/poser8updates.html
Bill
People that know everything by definition can not learn anything
Schurby posted Sat, 25 January 2014 at 8:05 AM
I use 8 on Windows 7 Pro, but be sure to use Explorer 10. Or you will have problems with your Library showing.
Schurby
goido posted Sat, 25 January 2014 at 10:48 AM
Thank you guys, I just got my new computer and I was planning on putting my library on my E: drive because my C: drive is a SSD and it is super fast but does not have lots of room. I will check which Explorer it has eventhough I use mostly Chrome. Hopefully with the library in a different drive it will not be a conflict if I have Explorer 11 pre installed.
hornet3d posted Sun, 26 January 2014 at 4:42 AM Online Now!
Quote - Thank you guys, I just got my new computer and I was planning on putting my library on my E: drive because my C: drive is a SSD and it is super fast but does not have lots of room. I will check which Explorer it has eventhough I use mostly Chrome. Hopefully with the library in a different drive it will not be a conflict if I have Explorer 11 pre installed.
I have the same setup and it seems to work fine. The E drive is accelerated by using another SSD fitted to the motherboard but the speed gain is minimal. I also have taken an image of the C drive in case the SSD fails and back up the E drive on a regular basis. In theory this should allow me to apply the image to a new SSD and continue or, in the case of an E drive failure, load the backup to a new conventional drive.
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
goido posted Sun, 26 January 2014 at 10:36 PM
Quote - > Quote - Thank you guys, I just got my new computer and I was planning on putting my library on my E: drive because my C: drive is a SSD and it is super fast but does not have lots of room. I will check which Explorer it has eventhough I use mostly Chrome. Hopefully with the library in a different drive it will not be a conflict if I have Explorer 11 pre installed.
I like that, I even have Colud based back ups because installing from scratch or losing files is a pain!!
