Cage opened this issue on Feb 09, 2014 · 2 posts
Cage posted Sun, 09 February 2014 at 6:06 PM
Has anyone seen this before? Do we have a workaround or fix for this issue? If this is a known bug, has it been reported to the Poser Team?
The problem here affects only the shoulder bend, with the distortion present on the collar.
Cage can be an opinionated jerk who posts without thinking. He apologizes for this. He's honestly not trying to be a turkeyhead.
Cage had some freebies, compatible with Poser 11 and below. His Python scripts were saved at archive.org, along with the rest of the Morphography site, where they were hosted.
Cage posted Sun, 09 February 2014 at 6:29 PM
Okay, I've found the problem. It isn't the joints, it's the joint magnet which is built into Antonia-WM to pull the pectoral down. Somehow the joint symmetry function made the magnet settings go kaflooey. Huh. Clearly magnets have no place in a joint setup. It's a pity we don't have a bulge map equivalent which moves along an axis. :unsure:
I suppose this still exposes a bug with the joint symmetry feature. It shouldn't be affecting magnets. Weird stuff, still.
