marciushess opened this issue on Feb 19, 2014 · 12 posts
marciushess posted Wed, 19 February 2014 at 9:44 AM
TeamSchmidt posted Wed, 19 February 2014 at 10:24 AM
I would try copying the runtime folder of the item in question to your desktop, then try manually loading it from there. Sometimes Poser and Daz will grab the wrong texture files if they have a similar names as another item. I have run into the issue alot, especially with Poser.
marciushess posted Wed, 19 February 2014 at 10:30 AM
OK, thanks, I'll try it.
markht posted Wed, 19 February 2014 at 12:38 PM
What do you have the UVs set to?
marciushess posted Wed, 19 February 2014 at 1:27 PM
Yep, this happened after I update the Genesis 2 Essentials. I reinstall the older versions and now it's working fine. Maybe some corrupted file inside the update. Thanks.
atpo posted Sat, 22 February 2014 at 1:14 AM
the same quession I have too.I think If can be done following :first export obj,then do uv map,and then use the right texture.
marciushess posted Sat, 22 February 2014 at 10:44 AM
I figure out the problem. I don't know how, but my V6 installation was corrupted, so I reinstall Victoria 6 and eerything is normal now.
Sabby posted Sun, 23 February 2014 at 2:04 PM
;) Glad this is all sorted, sorry I didn't see this thread earlier to help with this myself.
marciushess posted Sun, 23 February 2014 at 2:12 PM
Thanks Sabby.
Sabby posted Sun, 23 February 2014 at 9:24 PM
lol, thanks to the people who helped get it sorted out. : ) I like your avatar! ;)
atpo posted Tue, 25 February 2014 at 1:17 AM
congratulation
bhoins posted Fri, 28 February 2014 at 3:48 PM
Quote - the same quession I have too.I think If can be done following :first export obj,then do uv map,and then use the right texture.
Just go to the Surfaces tab and change the UV set.
