Subject: lipsync
darquevision opened this issue on Feb 20, 2014 · 2 posts
darquevision posted Thu, 20 February 2014 at 8:13 AM
hello again!
talking and lipsync is tricky i thought i had it under control but something changed and i dont know what. i recall there had to be some special specs for it to be understood by poser(pro). so i recorded at those levels and tried out a few with good results( aside from not being able to change facial expressions so easily, like in daz before). anyhow i was doing a test and needed some wav so i went to something new i record and it didnt work and so i tried something i used before that worked and it too didnt. then i tried the files that come with it and still unrecognized.
any thoughts?
thanx in advance
parkdalegardener posted Fri, 21 February 2014 at 8:36 AM
I can help with Poser's Talk Designer, but Mimic.... I didn't know it still worked outside of Studio. Just do a fourm search for "Talk Designer" posts made by me in the last 45 days. I'm pretty sure I wrote about this receintly. If you can give me more info on what Poser version , operating system, (matters with Talk Designer) and the rest I'll try and give you a better reply. You haven't really given me enough info to help.
