Subject: Scene Rotation?
dlm4001 opened this issue on Feb 23, 2014 · 3 posts
dlm4001 posted Sun, 23 February 2014 at 7:19 PM
I purchased a room with funiture and items.  The room and all items loads as props.  I want to use the room turned 90 degrees from what it loads by default. Is there a way to group all of these props for rotation?  I normally go into all 30 or 40 items and assign a new parent like floor. and then rotate it. This just seems like the hard way.  Is there a trick to getting all the objects to to rotate as one object or group?
I could load a null object, assign all the lights to it and just rotate the custom light set, but I want the references aligned with the view (z axis).
thanks for any help,
dlm4001
basicwiz posted Sun, 23 February 2014 at 9:07 PM
Check the heirarchy editor to see if everything is already parented to something. (They usually are in the scenario.)
dlm4001 posted Mon, 24 February 2014 at 12:51 PM
Thanks for the reply.  I did check the Heirarchy Editor and most of the room componenets were parented to the floor.  (I was rotating the wrong floor before, temp on that I added during compositiion. )  THis saved be a bunch of time. (thank you)
The rest of the items in the room were parented to UNIVERSE.  I had to manually reassign each one.  I wish there was a feature or a script to allow you to select many figures/props in a room and change a parameter that applies to all of them, like paraent. Seems like a script that I have heard of somewhere.
Dlm4001
