Subject: Render problems with Daz Sub Dragon Wings
RachealMarie opened this issue on Mar 05, 2014 · 4 posts
RachealMarie posted Wed, 05 March 2014 at 10:00 PM
When ever I try to render the Sub Dragon His wing membranes get dark blotches all over, I have tried all sorts of lighting, when I select the wings and uncheck raytracing they do render better but I can still see faint spots on the wings.
Would appreciate any info on this!
Medzinatar posted Wed, 05 March 2014 at 10:05 PM
Attach displacement slot to Simple_Color node set to white.  Put in a small displacement value of maybe start at 0.001 cm and increase till goes away
Medzinatar posted Thu, 06 March 2014 at 6:39 PM
I am thinking answer too abrupt, so I make the picture being better than my tries at english.  I show the before and after displacement applying, ending use of 6 mm for final value.  You should apply to both wing bottom and top. The value maybe different for different angles of wing.
RachealMarie posted Thu, 06 March 2014 at 9:10 PM
Thank you, will try this! :)
