Subject: Animated Props
moonlitmammerult opened this issue on Mar 21, 2014 ยท 3 posts
moonlitmammerult posted Fri, 21 March 2014 at 5:38 AM
I make a prop in max, it does this and that. But when I export and import as a .obj into poser whatever frame I was at that prop gets saved as that.
I could make it into an actor and then deal with it but I much rather keep it a prop.
Suggests, Links, ideas?
PhilC posted Fri, 21 March 2014 at 7:06 AM
You have two options.
  1. make the whole model into a figure.
  2. save the prop in its component parts and import each one separately.
My I ask why you want to keep it as a prop in poser rather than go the figure route?
moonlitmammerult posted Fri, 21 March 2014 at 4:59 PM
I thought wouldn't be able to set a parent to it. But turns out you easily can.
