EClark1894 opened this issue on Apr 06, 2014 · 17 posts
EClark1894 posted Sun, 06 April 2014 at 3:50 PM
Can it be done? I'm thinking that maybe I could create something like a tile shader with every other tile black. Then making a transmap?
EClark1894 posted Sun, 06 April 2014 at 3:51 PM
Latexluv posted Sun, 06 April 2014 at 4:57 PM
Weapons of choice:
bagginsbill posted Sun, 06 April 2014 at 5:04 PM
Good catch, LL!
I've been searching my posts for the last 45 minutes for that. I found the original thread but you beat me to it. I was having trouble because I didn't use the word fishnet in my post.
Latexluv posted Sun, 06 April 2014 at 5:34 PM
I've been trying to refind any shader you publically published because of a recent computer crash. Luckily I had some of your older shaders (pre PP2012), in my Poser Pro 2010 program on my external drive. I'm sure I'm still missing a bunch of your shaders! But I remembered using the fishnet shader on a shirt for M3 a long time ago.
Weapons of choice:
Winterclaw posted Sun, 06 April 2014 at 6:39 PM
U and V are supposed to be swapped, right?
Also, shouldn't the tile be plugged into the glossy node somewhere?
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
EClark1894 posted Sun, 06 April 2014 at 6:40 PM
bagginsbill posted Sun, 06 April 2014 at 6:49 PM
The glossy node is something LL did. My shader originally used white diffuse, not any specular. Rope is not shiny. I'm not sure what she was using that for, but a cotton string net is diffuse only.
The U and V are in the original only to rotate the tiles 45 degrees. You don't need them if you don't care about that.
Winterclaw posted Sun, 06 April 2014 at 7:09 PM
Ah, ok.
I'm playing with it now on DAZ's bodysuit... the one that comes in one of the V4 packages. Seams in the UV mesh can be a problem as is trim, so I wouldn't use it on anything but it does nicely.
WARK!
EClark1894 posted Sun, 06 April 2014 at 7:46 PM
toastie posted Sun, 06 April 2014 at 8:01 PM
Maybe you just need to tighten up the scale a lot?
Latexluv posted Sun, 06 April 2014 at 8:02 PM
I was trying for netting made of plastic strands. Some cheep stuff I saw on a cyber punk model once. Looked decent at the time that I rendered with it.
Weapons of choice:
EClark1894 posted Sun, 06 April 2014 at 8:20 PM
EClark1894 posted Sun, 06 April 2014 at 9:42 PM
toastie posted Mon, 07 April 2014 at 9:34 AM
Needs more layers, 3 isn't much for a tutu. Then the transparency will look better.
EClark1894 posted Mon, 07 April 2014 at 3:51 PM
Quote - Needs more layers, 3 isn't much for a tutu. Then the transparency will look better.
How many layers we talking?
toastie posted Mon, 07 April 2014 at 5:48 PM
Quote - > Quote - Needs more layers, 3 isn't much for a tutu. Then the transparency will look better.
Usually about 8-10, but you could get away with a few less for a class practice tutu though. I think that like a real tutu it will probably look better the more layers you add.
