thanos67 opened this issue on Apr 11, 2014 · 4 posts
thanos67 posted Fri, 11 April 2014 at 4:06 PM
Is Poser 10, Poser Pro 2012 compatible with the content in Poser 6? Like CR2, PP2, victoria 4 and her clothing, Hair, Props, Poses. I want to upgrade to either Poser 10 or Poser Pro 2012 which would be best.
JimTS posted Fri, 11 April 2014 at 4:17 PM
Scripts from Poser 8 and lower use a different Python version than 10 Pro 2012
Check the feature comparison chart at SM site
I'd go Poser Pro 2012 (that sorta rymes)
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
hborre posted Fri, 11 April 2014 at 5:52 PM
Otherwise, everything is usable. You will need to relearn Poser because P6 hacks and cheats will not longer apply to P10 and PP2012 (or do you really mean PP2014?).
WandW posted Fri, 11 April 2014 at 8:57 PM
To use your Poser 6 content in a recent version of Poser, copy the entire Poser 6 program folder out of Program Files (presuming you are on Windows) and add the Poser 6 runtime to the new Poser's Library as an external Runtime, and you will have access to all of your old content. Poser 6 will still work after moving it, too if you make a new shortcut to Poser.exe.
You may need to convert any rsr files to png thumbnails; I dont recall if Poser 6 converted them automatically. Here ia a Windows converter...
http://neocron.webspaceforme.net/alforum/index.php?topic=1489.0
