mrsparky opened this issue on Apr 19, 2014 · 9 posts
mrsparky posted Sat, 19 April 2014 at 10:12 AM
Attached Link: http://www.sparkyworld.co.uk/3d10own.htm
Inspired by the work of the etsy artist Ambassadormann, this rather nifty pair of highly detailed goggles is perfect for your SteamPunk aviators. Powered by a small steam engine, it can turn a series of cogs to drive a set of lenses that has so much magnifaction, you can see up a Scotmans kilt while standing on the Isle of Wight.* The vacum tubes can illuminate the target cross-hairs which means you'll never miss a low flying haggis again. Plus theres no rear head strap, so it'll fit under hair and hats better. Set contains a model on poser prop format, so it'll work on any figure with a slight tweak of the parameter dials. It also has a set starter textures, which for best results should be replaced with app specific shaders like in the images below. Renders 1 & 3, custom Reality. ** Note: Only when it's not raining in the UK.*mrsparky posted Sat, 19 April 2014 at 10:12 AM
mrsparky posted Sat, 19 April 2014 at 10:13 AM
byudragonbreath posted Sat, 19 April 2014 at 11:47 AM
RFreise posted Sat, 19 April 2014 at 1:29 PM
Thank You
bobbystahr posted Sat, 19 April 2014 at 5:25 PM
Thanks mrsparky...cool copter as well...
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
tyllo posted Wed, 23 April 2014 at 8:26 PM
Beautiful googles!
Thanks a bunch, mrsparky!!! :)
mrsparky posted Thu, 24 April 2014 at 7:48 AM
Thanks all! This is going to the last one for 2-3 weeks as I'm just starting on a new project that will be blending a mix of 3D freebies, photography and tutorials. Some of which I'll be asking the community for help with.
bobbystahr posted Sat, 26 April 2014 at 2:09 PM
Quote - Thanks all! This is going to the last one for 2-3 weeks as I'm just starting on a new project that will be blending a mix of 3D freebies, photography and tutorials. Some of which I'll be asking the community for help with.
Ask away
Once
I see
a sound
and
Sometimes
