timewyrm opened this issue on May 04, 2014 · 12 posts
timewyrm posted Sun, 04 May 2014 at 2:37 PM
Is it possible to get clothing to fit She Freak V4? I tried injecting the morph into the bodysuit, but whilst it appeared as a dial it had no effect.
EClark1894 posted Sun, 04 May 2014 at 2:55 PM
I believe the morphs have to be "built into" the suit to work. I never had She-freak (any version) cause frankly I thought she was a waste of time and effort, so I'm only going by what I recall of other morphs for V4 like Aiko, the Girl and Stephanie. Hope that helps.
aldebaran40 posted Sun, 04 May 2014 at 3:24 PM
if you have poser 2014, you can use the fitting room , a external script like "Morphing Clothes" or "crossdresser 4.0" (a friend used this latter and conforms) I could do that that you want ( Since I not used any of them so I can not advise any )
I particularly fix the clothes in zbrush so I do not know if it's an option that can help you.
I've found very useful for "extreme" big muscles,non conventional bodies , characters giant breasts etc ... is the dynamic clothing, with a little practice it makes clothes that fit well with your models also
Medzinatar posted Sun, 04 May 2014 at 3:46 PM
timewyrm posted Sun, 04 May 2014 at 4:11 PM
Thanks everyone - Im still using Posr 9. Might be time for an upgrade then......
EClark1894 posted Sun, 04 May 2014 at 4:52 PM
vilters posted Sun, 04 May 2014 at 5:33 PM
"Copy Morphs from" is only available in PP2014.
it can be found in 3 places:
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
PhilC posted Sun, 04 May 2014 at 8:19 PM
Poser 9 has Wardrobe Wizard that can do the job provided that you have the V4 support files.
moriador posted Sun, 04 May 2014 at 11:22 PM
Quote - Poser 9 has Wardrobe Wizard that can do the job provided that you have the V4 support files.
I believe this would be the least expensive route to take.
Edit: I do have a question for you, Phil. For crossfigure conversions (e.g. V2 to V4) do you need both the 'to' and 'from' support files? (I think I've got most of the ones I need anyway, but I'd like to know. I might need more of them.)
PhilC posted Mon, 05 May 2014 at 4:07 AM
Yes you need the support files for both the to and from figure. SheFreak is I believe a morph off V4 so you just need V4.
moriador posted Mon, 05 May 2014 at 6:19 AM
Quote - Yes you need the support files for both the to and from figure. SheFreak is I believe a morph off V4 so you just need V4.
That makes sense. Thank you. :)
EClark1894 posted Mon, 05 May 2014 at 7:24 AM
